Guest rhd_2jz Posted December 7, 2009 Share Posted December 7, 2009 Has anyone running an AEM EMS in a J-spec mkiv(non vvti) encountered the slip control light blinking when the car is keyed to the ON position? As far as i can tell the ecu pins are the same except pin 67 in the B cluster goes to the traction control ecu on the jspec pinout and the us/uk goes to nothing?? I called AEM about this issue and they had no experience with the j spec cars. grrr any help would be appreciated. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted December 7, 2009 Share Posted December 7, 2009 Have you got the traction control ECU plugged in still? Its the box next to the ECU, just disconnect and your problem will go away. Quote Link to comment Share on other sites More sharing options...
Guest rhd_2jz Posted December 7, 2009 Share Posted December 7, 2009 Yes I do actually. So unplugging the other computer will make this light go off and what adverse effects does that have. I'm not 100% positive exactly all that box does. Thanks! Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted December 7, 2009 Share Posted December 7, 2009 Just remove it, its not doing anything with the AEM installed. Quote Link to comment Share on other sites More sharing options...
