SteveR Posted December 22, 2009 Share Posted December 22, 2009 Jon, I don't think you want to run the cylinder's operating pressure directly to the horns - that's pretty scary TBH. IMHO there are two main issues with that approach: you'll find even with better washers that sort of pressure will just blow the next weakest link, and the next, and the next The operating pressure of the horns will depend on the presure in the cylinder, every time you use it, this will drop. IMHO if you insist on using the diving cylinder (please strap it down properly, you don't want a lump like that coming loose in the event of a shunt/accident) then you will need to run a 1st stage to drop the pressure to a constant, just the same as is done with scuba diving equipment. THe 1st stage is the lump that attaches directly to the cylinder and then feeds several high & "low" pressure hoses from it, "low" being 10 bar above the surrounding ambient pressure. 10 bar is more than enough for even the loudest car horns, quite possibly still way too much from both a safety and a return/performance/loudnest PoV as I reckon there will be a clipping point where you can keep increasing the pressure but the horns get no noticeable amount louder. This approach will also mean your gas will last a LOT longer, as you'll be bleeding it away at a much slower rate. Quote Link to comment Share on other sites More sharing options...
Pig Posted December 22, 2009 Author Share Posted December 22, 2009 Jon, I don't think you want to run the cylinder's operating pressure directly to the horns - that's pretty scary TBH. IMHO there are two main issues with that approach: you'll find even with better washers that sort of pressure will just blow the next weakest link, and the next, and the next The operating pressure of the horns will depend on the presure in the cylinder, every time you use it, this will drop. IMHO if you insist on using the diving cylinder (please strap it down properly, you don't want a lump like that coming loose in the event of a shunt/accident) then you will need to run a 1st stage to drop the pressure to a constant, just the same as is done with scuba diving equipment. THe 1st stage is the lump that attaches directly to the cylinder and then feeds several high & "low" pressure hoses from it, "low" being 10 bar above the surrounding ambient pressure. 10 bar is more than enough for even the loudest car horns, quite possibly still way too much from both a safety and a return/performance/loudnest PoV as I reckon there will be a clipping point where you can keep increasing the pressure but the horns get no noticeable amount louder. This approach will also mean your gas will last a LOT longer, as you'll be bleeding it away at a much slower rate. Thanks for your advise, I appreciate it and I am listening to what your saying even if im coming across like im not I have attached a drawing of my setup (excuse how rubbish it is) does it make sense? I have highlighted the pressurised section as my understanding is that this is the section where all parts need to be designed exatly for that purpose. After that, should i look at changing the nylon pipe for something a little stronger? Please note, that the washers are plastic. See here for example http://www.hadley-products.com/catalog/Catalog.aspx?cmd=prd&div=4&srch=1&prd=147 http://www.hadley-products.com/catalog/Catalog.aspx?cmd=prd&div=3&cat=32&prd=36 Oh and I havent got a regulator yet. Can you please point me in the right direction for what I need? Double Oh, I shall secure the tank in the boot VERY securly. Thanks again, Jon Quote Link to comment Share on other sites More sharing options...
Pig Posted December 22, 2009 Author Share Posted December 22, 2009 Only just spotted this thread, looks like a lot of fun Jon Did you manage to make use of the exhaust in the end? Not yet, not sure how im going to make it happen yet! Will keep you in the loop though. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted December 22, 2009 Share Posted December 22, 2009 Looks good. Our scumrun project will be under wraps until launch day, but we've now found our perfect stallion Quote Link to comment Share on other sites More sharing options...
SteveR Posted December 23, 2009 Share Posted December 23, 2009 Thanks for your advise, I appreciate it and I am listening to what your saying even if im coming across like im not Not at all, I'm probably coming across a bit OTT but I'd rather be clear than think I'm leaving anything like this open to interpretation. I have attached a drawing of my setup (excuse how rubbish it is) does it make sense? Yep, makes sense to me and I can see what you're hoping to achieve. I have to admit though, I'm still not sure how you'll be able to use SCUBA without more SCUBA kit - the 1st stage regulator for example. I can't think of anything that would do the job of a pressure regulator, and bolt to the top of a diving cylinder, other than a (1st stage) diving regulator. That would then have the advantange of working perfectly with the associated hoses from diving, which - in theory at least - you could buy in an extra long lenth and run al the way to the horns. http://www.leisurepro.com/Image/Product/Large/XSSQDH.jpg The only tricky bit left is making an attachment for the horns to work with the pressurised diving hose, which shouldn't be too difficult: either work with that shown above, or perhaps an open end with a bloody tight banjo or three would be worth a go if we're 'only' talking about 10 bar. Quote Link to comment Share on other sites More sharing options...
Pig Posted December 23, 2009 Author Share Posted December 23, 2009 Cool. Am having my step son (the diving instructor) make me up the scuba section as he has a 2m hose coming off his re-breather and a first stage spare. Think were there but I will have to wait till he gets back out to eygpt so he can send it all back. Will keep you in the loop bud. Jon Quote Link to comment Share on other sites More sharing options...
marc_p Posted December 24, 2009 Share Posted December 24, 2009 Always wanted to do the scumball, looks like a lot of fun I can't imagine the women being as good as the ones on the gumball though. Quote Link to comment Share on other sites More sharing options...
SteveR Posted December 29, 2009 Share Posted December 29, 2009 Cool. Am having my step son (the diving instructor) make me up the scuba section as he has a 2m hose coming off his re-breather and a first stage spare. Think were there but I will have to wait till he gets back out to eygpt so he can send it all back. Will keep you in the loop bud. Jon Quote Link to comment Share on other sites More sharing options...
Pig Posted January 17, 2010 Author Share Posted January 17, 2010 Thanks to John for the spoiler Was exactly what i was looking for. For those wondering, it is meant to look stupid (after all, its for charity) The brakets are meant to hold a ladder up and are nice and strong. Just been out and tested it to 100 leptons and it holds fine. Im getting good at the old handywork. Quote Link to comment Share on other sites More sharing options...
supragold Posted January 18, 2010 Share Posted January 18, 2010 OMG i saw this on facebook and was like WTF. Didn't know it was for a scumrun. Just thought you had lost the plot hahaha Quote Link to comment Share on other sites More sharing options...
monsween Posted January 18, 2010 Share Posted January 18, 2010 Did you manage to sort out the fittings/hoses stuff? Quote Link to comment Share on other sites More sharing options...
AlexM Posted January 18, 2010 Share Posted January 18, 2010 I think the spoiler would look better on the 2CV Jon. Quote Link to comment Share on other sites More sharing options...
mr lover Posted January 18, 2010 Share Posted January 18, 2010 Jon your neighbours must think WTF is he doing now Quote Link to comment Share on other sites More sharing options...
Pig Posted January 18, 2010 Author Share Posted January 18, 2010 OMG i saw this on facebook and was like WTF. Didn't know it was for a scumrun. Just thought you had lost the plot hahaha Lol, I really would have lost it Still in stortford? Fancy a beer some time? Did you manage to sort out the fittings/hoses stuff? Still going, ordered a 1st stage off of ebay last night. I think the spoiler would look better on the 2CV Jon. Jon your neighbours must think WTF is he doing now They are used to me now Now on a serious note. I know the run is for charity and the car is meant to be a joke BUT should i find a way of lowering the spoiler? My other team mates reaction wasnt what i expected. So its made me doubt it. Please be honest. Quote Link to comment Share on other sites More sharing options...
Pig Posted January 21, 2010 Author Share Posted January 21, 2010 Got the air horn setup working now. Used a first stage as discussed in the previous post (thanks steve) will post pics and vid when they are on the car Quote Link to comment Share on other sites More sharing options...
gaz1 Posted January 21, 2010 Share Posted January 21, 2010 would love to see your face when you get to the ferry and they charge you the price for a lorry because of your cars height:p Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted January 21, 2010 Share Posted January 21, 2010 car looks shit but in a good way mate lol Quote Link to comment Share on other sites More sharing options...
Pot Posted January 21, 2010 Share Posted January 21, 2010 Only just seen this thread, got to say fair play to you all - That spoiler looks fantastic! The sheer over the topness of it fits in with the hilarity of the event Quote Link to comment Share on other sites More sharing options...
ronttuk Posted January 21, 2010 Share Posted January 21, 2010 did you get the cb fitted jon? Quote Link to comment Share on other sites More sharing options...
Pig Posted January 22, 2010 Author Share Posted January 22, 2010 would love to see your face when you get to the ferry and they charge you the price for a lorry because of your cars height:p You know i would get the hump and take the spoiler off for the journey out of principle car looks $#@! but in a good way mate lol That was the idea, thanks so much for the spoiler. It was EXACTLY what i wanted. Only just seen this thread, got to say fair play to you all - That spoiler looks fantastic! The sheer over the topness of it fits in with the hilarity of the event Thanks, thats what i though. Do you think i should paint the bike wall mount (bits holding spoiler up) in black? did you get the cb fitted jon? Not yet, Air horns to go on next then the CB. Need to find a way of securing it so it doesn't all over after 60mph. Quote Link to comment Share on other sites More sharing options...
ronttuk Posted January 22, 2010 Share Posted January 22, 2010 jon if you want to drill a hole in the mag mount so you can screw it to the roof go for it, ive no idea when i will use it again or you can unbolt the ariel fitment from the mag mount drill a hole and fit it direcftly to the roof and not use the magnets Quote Link to comment Share on other sites More sharing options...
marc_p Posted January 22, 2010 Share Posted January 22, 2010 I love it, I think you should do some cardboard arches aswell:d Quote Link to comment Share on other sites More sharing options...
Pig Posted January 22, 2010 Author Share Posted January 22, 2010 jon if you want to drill a hole in the mag mount so you can screw it to the roof go for it, ive no idea when i will use it again or you can unbolt the ariel fitment from the mag mount drill a hole and fit it direcftly to the roof and not use the magnets Cool, Thanks mate. That will make life easier I love it, I think you should do some cardboard arches aswell:d Lol, i wouldnt want it to look silly Quote Link to comment Share on other sites More sharing options...
Pig Posted January 24, 2010 Author Share Posted January 24, 2010 Rodney now has his truck horns all setup (just need to finish the interior mounting) Video to follow Quote Link to comment Share on other sites More sharing options...
Pig Posted January 24, 2010 Author Share Posted January 24, 2010 [YOUTUBE][/YOUTUBE] Quote Link to comment Share on other sites More sharing options...
