Guest ravi Posted December 5, 2009 Share Posted December 5, 2009 we installed misimoto radiator and rad cap and after market fans still overheating when driving long periods ( 45mins) and i smell alot of burnt oil. i dont over heat in traffic the radiator hose both top and bottom are not clogged and there is no air lock in the system there is a crackling noise under the turbos an a lot of steam at the rear of the engine. i thinking either waterpump thermostat (after i remove do i have to replace since i like in the caribbean) or even head gasket ( not seeing an bubbles when the car idling so doubt it) i used proper weighted amsoil oil and i dont have an oil cooler only running 15 psi right now which is stock .. on the brighter side i beat ths fuk out of a ninja this morning.. and yes he was trying to race me,,, i crushed him... felt great(best birthday gift ever).. cant wait to get this problem solved and run my single turbo setup:) Any positive suggestions would be widely appreciated :0 Link to comment Share on other sites More sharing options...
nigelboyne Posted December 5, 2009 Share Posted December 5, 2009 is the car loosing coolant could be just a air lock Link to comment Share on other sites More sharing options...
Guest ravi Posted December 5, 2009 Share Posted December 5, 2009 positive its not Link to comment Share on other sites More sharing options...
Dave17 Posted December 5, 2009 Share Posted December 5, 2009 So you're car is not right and you are racing motorbikes in it. Prime example why ownership should be limited to people who actually care about cars. Link to comment Share on other sites More sharing options...
Darron Q Posted December 5, 2009 Share Posted December 5, 2009 So you're car is not right and you are racing motorbikes in it. Prime example why ownership should be limited to people who actually care about cars. Amen to that Dave on another note Ravi i am sure the more clued up members will be along in a min to help u out Link to comment Share on other sites More sharing options...
absz Posted December 5, 2009 Share Posted December 5, 2009 If you are getting a lot of steam on the rear of engine, then the first thing to check is the heater hose that goes on top of the cylinder head at the rear, they do go hard and brittle over time. Link to comment Share on other sites More sharing options...
Dnk Posted December 6, 2009 Share Posted December 6, 2009 If you are getting a lot of steam on the rear of engine, then the first thing to check is the heater hose that goes on top of the cylinder head at the rear, they do go hard and brittle over time. Good call. If you have steam then you have a leak somewhere. Link to comment Share on other sites More sharing options...
JODY T Posted December 6, 2009 Share Posted December 6, 2009 Good call. If you have steam then you have a leak somewhere. yeah but with that problem, it would only overheat when the water runs low.. top it back up and it would be okay untill it leaked out.. Link to comment Share on other sites More sharing options...
Dnk Posted December 6, 2009 Share Posted December 6, 2009 yeah but with that problem, it would only overheat when the water runs low.. top it back up and it would be okay untill it leaked out.. not sure what your on about, any water leak on a car engine will eventually cause overheating, obviously if you top it up it wont overheat until the leak gets bad enough The op says he's not losing water yet has steam at the back of the engine, i dont see how that is possible as the only way you get steam is from having a water leak. Better info is required from the op to help sort his problem in my opinion Link to comment Share on other sites More sharing options...
