Is my phone knackered?
Jake
My phone, a Nokia N95 (original one not the 8gb model) has suddenly stopped sending text messages. When I try to send a text, after it going into the Outbox and showing "Sending..." it then comes up with :
Unable to send message:Fred Bloggs
Text message: check network services
WTF does that mean? I've googled it and found several folks with the same problem - but I've yet to find a solution.
I've reset the phone.
Installed the latest firmware
Fitted a SIM from another provider.
Still the same problem.
Is the phone borked ?
Do you have quite a lot of texts saved in the phone? Maybe 1000 including sent items, deleted and all other text folders?
I had the same issue with my old N95 and resolved it by connecting it up to the PC suite, deleting all texts using that and then switching the phone off and on again.
I had an Orange SIM when the problem started. I've since fitted an O2 SIM but still have the same problem. So I'm guessing it isn't gonna be a network provider issue, right?
Co-incidentally, the problem started the day after I had an argument with Orange because I wanted web access enabled on my SIM so I could use it in my Sony Satio. They wouldn't do it 'cos I don't know the PIN for the SIM, so I told them I'd take my business to another provider once my credit had run out.
It still may, because settings will differ for both providers.
Guest vintage21275
have same problem with my blackberry o2 network had to send the phone away for repair waiting to get it back..some sort of software problem
p.s could be the mesage centre number causing the problem have had that problem once, you might have to call o2 and get them to help you put that in
You out of credit mate ;)
Nah :D
I've just discovered that I CAN send a (MMS?) message, ie a photo taken on the phone I was able send to myself OK.
Still can't send texts though.
Oh God, I hate calling call centres.
Yay! It's fixed.
Called O2, they got me to check some settings and found that the "Message Centre" was set to the wrong phone number in (Messaging > Options > Settings >Text Message > Message Centres > SIM message centre )
Thank you "vintage21275" - you were dead right. :thumbs:
