Digital Posted December 4, 2009 Share Posted December 4, 2009 The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers. Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture. 200 pounds. Link to comment Share on other sites More sharing options...
movistar Posted December 4, 2009 Share Posted December 4, 2009 Euro is rubbish for us at the moment in the UK....change the 3 to a 2 and you might get lucky. good luck. Link to comment Share on other sites More sharing options...
Geo Posted December 4, 2009 Share Posted December 4, 2009 get one brand new for that price dude... Maybe consider dropping the price some more. Link to comment Share on other sites More sharing options...
Digital Posted December 4, 2009 Author Share Posted December 4, 2009 Looking at Whifbitz, they charge 380 pounds for a new one. But I saw JamieP is asking 200 pounds for his, so same price here. Link to comment Share on other sites More sharing options...
chico Posted December 14, 2009 Share Posted December 14, 2009 u still have it?? Link to comment Share on other sites More sharing options...
Lee P Posted December 14, 2009 Share Posted December 14, 2009 Looking at Whifbitz, they charge 380 pounds for a new one. But I saw JamieP is asking 200 pounds for his, so same price here. Yes but Jamie's is the new one (DLI II) which is current. Your is the older version. Link to comment Share on other sites More sharing options...
