Whifbitz manifold cheap
Paul Whiffin
I've got a pre production version of one my new design manifolds going cheap at the moment. Its a new version with the wastegate moved so its accessable under the engine bay which is great for anyone wanting to change wastegate springs easily. Reason why its cheap is because there's not a lot of room to get a silicon pipe on the compressor housing, basically it was made slightly wrong. Its absolutely fine if you weld a pipe on the housing though, bit of a bargain as these are normally over £1000, brand new and unused £600.
http://www.garagewhifbitz.co.uk/images/stories/gw_images/2ndhandparts/manifold.jpg
