TRD Oil Caps
Guest Rays the roof
  • Replies 63
On the NA (mine anyway) it faces forward and it is from the same batch.
Hodge & DNK ? How are yours?
Mine sits on an angle, thats why i asked if you could get the genuine sticker and i was going to change it.
Looks bad the way it is, i'll take a pic if you wish
Where did you get them from Ray? I'm pretty sure they aren't genuine. Have a look at the depth of the "dish" area on mine compared to the likes of Dunk's. Seems really shallow in comparison.
Just having another look at it I'm thinking that they may be for a different car with the same fitting? Perhaps the seller noticed that the fitment was the same, but the design was different?
Mine sits the same, tweak it back a bit and looks ok but better if the sticker was the other way, i was tempted to try and peel it off and turn it around.
You mean undo the cap a bit ? no thanks i'd prefer it to be fully shut :) and surely the logo should read as Scott M's from the front ?
I was tempted to see if the sticker would come off but im not going to risk it.
Guest Rays the roof
The supplier is a guy I know who imports TRD stuff from Japan, so I know they are genuine. I can only think that they are for another Jap car but would expect the fitting of the oil cap to be identical??
Confused.com
PS if anyone is unhappy with the cap return it for a full refund :)
No problem!
Confused.com
No problem!
Where the cap rotates to will depend on the orientation of the cut outs in the cam cover
If you could get me one with the sticker lining up the same as Scott M's then great and swap the one i have.
If refund is the only option then i'll send it you back
Want me to go out and take some pics... on and off the car etc?
You can do but not sure how it will help Ray, they should send the sticker and cap seperate then when you put the cap on your car you can apply the sticker where ever you want it ;)
Bump
Guest Rays the roof
Bump
I will PM you address to return the cap. I will test it against mine and either send you one back that you will be happy with or send a full refund.
Ramondo
Ramondo
Thanks Ray, i want the cap but want the sticker to line up so if you can replace with one that lines up then great, im happy to wait if you get a new batch in the near future
Cheers
Dunk
Can TRD badges for oil caps be purchased, as mine got lost.
I asked Ray if he could get them as i'd of just peeled off the one on my oil cap and fitted a new one but inline.
He said he couldnt get them when i asked a couple of weeks ago
Guest Rays the roof
Take a look below:
Two identical GENUINE caps fitted to NA (right) and TT (left) cam covers.
picture.php?albumid=261&pictureid=2405
And the reason is:
picture.php?albumid=261&pictureid=2406
Yet another reason why the NA is better than the TT :p
Dunken - I am happy to attempt to remove and replace the sticker if you accept the risk. Otherwise I will refund you and sell onto another member. I am happy to do either.
Mine is genuine and fits square though Ray.
Is it possible that there is a TT unit and an N/A unit?
Having a look at Dunk & Jamies posts they would seem to note that they are off center when tightened on properly, they don't sit at exactly 90 degrees from square as per your pic.
Take a look below:
http://www.mkivsupra.net/vbb/picture.php?albumid=261&pictureid=2405
And the reason is:
http://www.mkivsupra.net/vbb/picture.php?albumid=261&pictureid=2406
If mine sat square either way like yours in the pics then fine i'd live with it but it doesnt, if you look at my pic its on the skew when properly turned shut.
Im not keen on you trying to remove and refit the sticker at my risk so if you cant supply the correct fitment for a tt then i'll have my money back
  • 2 weeks later...
Guest SupraGTE
just info i have a many year old TRD cap (think it is from 2003) and also all i fitted is like that :(
i just turn it back a bit that it is straight and live with it :)
