Stephen G Posted December 2, 2009 Share Posted December 2, 2009 The other day when i started my car the OD light started to flash and when i selected D the car let a violent snap forword. On the move the car shifted up snappy aswell and when i put my foot down it would not kickdown. This does not happen everytime most of the time it work perfect! The oil level is spot on aswell so its not that or is it the box telling me it about to give up. Any ideas? it a uk spec aswell if that makes any difference Quote Link to comment Share on other sites More sharing options...
baldy Posted December 2, 2009 Share Posted December 2, 2009 have you checked the fault codes? Quote Link to comment Share on other sites More sharing options...
Stephen G Posted December 2, 2009 Author Share Posted December 2, 2009 not yet Quote Link to comment Share on other sites More sharing options...
paul mac Posted December 2, 2009 Share Posted December 2, 2009 as Baldy says, fault codes is your first port of call, if you have had the OD light on there will definately be fault codes stored, let us know what it is and we'll take it from there Quote Link to comment Share on other sites More sharing options...
tomgeer Posted December 2, 2009 Share Posted December 2, 2009 Try resetting your ecu Quote Link to comment Share on other sites More sharing options...
paul mac Posted December 2, 2009 Share Posted December 2, 2009 Try resetting your ecu no you will loose the eroor codes and then be back to square one waiting for the fault again Quote Link to comment Share on other sites More sharing options...
Stephen G Posted December 2, 2009 Author Share Posted December 2, 2009 cheers lads i will check the codes tomorrow when i finish work and put them up for yous Quote Link to comment Share on other sites More sharing options...
Stephen G Posted December 3, 2009 Author Share Posted December 3, 2009 just checked the fault code The od light flashed 8 times paused and then 9 times checked with my service disk but cant find it Any ideas? Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 3, 2009 Share Posted December 3, 2009 89 code got the same prob ive tried new manu button, trac ecu, delimeter, and moving tps sensor, i was told its communication problem between ecu and trac ecu if you find what it is please share Quote Link to comment Share on other sites More sharing options...
baldy Posted December 3, 2009 Share Posted December 3, 2009 ill have a look at the manual in the morning,its at work Quote Link to comment Share on other sites More sharing options...
Stephen G Posted December 3, 2009 Author Share Posted December 3, 2009 ill have a look at the manual in the morning,its at work cheers mate Quote Link to comment Share on other sites More sharing options...
baldy Posted December 4, 2009 Share Posted December 4, 2009 well the repair book says, fault code 89.trouble area, harness or connector between trc ecu and engine and ect ecu if all connections look ok,then try another trc ecu hth Quote Link to comment Share on other sites More sharing options...
Stephen G Posted December 4, 2009 Author Share Posted December 4, 2009 thanks mate i take a look in the morning see how things go Quote Link to comment Share on other sites More sharing options...
