ADD Posted December 2, 2009 Share Posted December 2, 2009 (edited) As my hybrids have had a paddy and the seals have gone, i was thinking of putting a single on, with the mods i have at the moment what else would i need to get to support a T61 please? I know id need a manifold and downpipe..... Current mods: EMU, Blitz SBC ID III, 550cc, Resistor Pack, Miami-GT FMIC, TRL FCD, Denso IK24's, Walbro fuel pump, Nur spec, Full Whifbitz decatt, CW RR, HKS SSQV, AEM Wideband, HKS Oil Pressure and Water Temp. Thanks Edited December 2, 2009 by ADD (see edit history) Link to comment Share on other sites More sharing options...
heckler Posted December 2, 2009 Share Posted December 2, 2009 sounds pretty much what I had as mods before i stuck my single on - All I did was put bigger injectors in Link to comment Share on other sites More sharing options...
j80leo Posted December 2, 2009 Share Posted December 2, 2009 (edited) Compression test leak down test if no good fuel pressure regluator wastegate oil cooler screamer pipe/recirc pipe What miles are on the engine as if its alot then parts will be tired and need changing for stock new parts or modded depending how much horsepower you are wanting. Edited December 2, 2009 by j80leo (see edit history) Link to comment Share on other sites More sharing options...
Jamesy Posted December 2, 2009 Share Posted December 2, 2009 wow didnt realise you dont actually need masses of aftermarket spec to get a single on there. Obviously a remap in there after too!! I have pretty much the same as you ADD minus the injectors and EMU ... hmmmm, you have put BAD thoughts in my mind dude. Link to comment Share on other sites More sharing options...
j80leo Posted December 2, 2009 Share Posted December 2, 2009 You don't need loads of bits some are extra's and piece of mind;) just buy quality bits but this is where the money comes into it. Link to comment Share on other sites More sharing options...
Alex Posted December 2, 2009 Share Posted December 2, 2009 650cc injectors would be good but you could probably get one up and running at 0.8bar on the 550's. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 2, 2009 Share Posted December 2, 2009 I can run up to 1.35 BAR on my 540cc injectors, i suspect they are actually flowing 600cc or over, Anyway to respond to the original question i would say you have it pretty much covered, just add an oil cooler, obviously with all the turbo ancillaries. Link to comment Share on other sites More sharing options...
paul mac Posted December 2, 2009 Share Posted December 2, 2009 (edited) have a look in my garage as i have run a T61 for the last 4 years, before you rush out and buy a tubular manifold i would seriously consider a cast manifold, unless you plan on running 700hp in the future , faster spool and much more compact, also a 3200rpm hi stall torque converter will absolutely transform the car Edited December 2, 2009 by paul mac (see edit history) Link to comment Share on other sites More sharing options...
heckler Posted December 2, 2009 Share Posted December 2, 2009 Cast Manifold here too... Link to comment Share on other sites More sharing options...
ADD Posted December 2, 2009 Author Share Posted December 2, 2009 Thanks all for ya responses sorry for late reply, im working night shifts this week. The car has done 105k and i would most def get a compression and leak down test done before going any further. When you say turbo ancillaries what exactly are they? How much woukld i be looking at for a T61 price wise? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 2, 2009 Share Posted December 2, 2009 " When you say turbo ancillaries what exactly are they?" Basically manifold, turbo, down pipe,waste gate, screamer pipe, oil and water feeds and drains, pipework, filter, you seem to have the rest. Link to comment Share on other sites More sharing options...
Steve Posted December 2, 2009 Share Posted December 2, 2009 How much woukld i be looking at for a T61 price wise? http://www.mkivsupra.net/vbb/showthread.php?t=203210 £500 there Link to comment Share on other sites More sharing options...
Homer Posted December 2, 2009 Share Posted December 2, 2009 It's been pretty much covered already, but would just add that if you are not aiming for really high power figures I'd seriously consider a cast manifold over the tubular ones. With a smaller turbo like the T61 it makes much more sense. Only drawback is they don't sound that great, but that's a minor thing Link to comment Share on other sites More sharing options...
ADD Posted December 2, 2009 Author Share Posted December 2, 2009 lads that awesome thank you very much for the information! Then the cost of fitting of course Homer is there a big price difference between tubular and cast? The noise is rather important Link to comment Share on other sites More sharing options...
Homer Posted December 2, 2009 Share Posted December 2, 2009 Homer is there a big price difference between tubular and cast? The noise is rather important Cast tends to be cheaper but a lot depends on which system you choose - that's the really important bit. Noise wise I would say the cast is a bit quieter, but they do have their drawbacks. From the half dozen or so I've heard or driven they don't sound quite as nice off boost, but with an open screamer pipe you won't notice any difference once it's on full chat. Link to comment Share on other sites More sharing options...
ADD Posted December 3, 2009 Author Share Posted December 3, 2009 Cheers homer, it would seem the manifolds are more expensive than the turbo :0 Link to comment Share on other sites More sharing options...
Steve Posted December 3, 2009 Share Posted December 3, 2009 Some folks on here have used the Treadstone Cast Manifold which are very well priced. http://www.treadstoneperformance.com/product.phtml?p=325&cat_key=52&prodname=Toyota+Supra+2JZGTE+Turbo+Manifold Link to comment Share on other sites More sharing options...
Homer Posted December 3, 2009 Share Posted December 3, 2009 Cheers homer, it would seem the manifolds are more expensive than the turbo :0 Tubular ones tend to be, but cast are a lot less. Link to comment Share on other sites More sharing options...
