luisito-awo Posted December 1, 2009 Share Posted December 1, 2009 i got a 93 manual n/a toyota supra when i start it it just stop working after like 40 secs and when i start it and rev it the engine just stop working i dont know if u could know what the prob is Quote Link to comment Share on other sites More sharing options...
beagle Posted December 1, 2009 Share Posted December 1, 2009 hi i had similar thing happened to mine started it up let it warm up then gave it a couple of revs then engine just stopped (cut a long story short) it was the coil got new one everything ok . Quote Link to comment Share on other sites More sharing options...
HadeS Posted December 1, 2009 Share Posted December 1, 2009 I had exaclty the same when I run out of petrol ;] Quote Link to comment Share on other sites More sharing options...
luisito-awo Posted December 2, 2009 Author Share Posted December 2, 2009 hi i had similar thing happened to mine started it up let it warm up then gave it a couple of revs then engine just stopped (cut a long story short) it was the coil got new one everything ok . ok i will chek the coil Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted December 2, 2009 Share Posted December 2, 2009 check the vacume pipe has not come off the bottom of the map sensor located on the bulkhead on the inlet side of the engine, Quote Link to comment Share on other sites More sharing options...
