jkr46 Posted December 1, 2009 Share Posted December 1, 2009 N/A - T turbo kit for sale on ebay item no 120500587196 Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 1, 2009 Share Posted December 1, 2009 what make of kit is this?? why you selling?? im interested.. does it need different injectors and ecu to run it Link to comment Share on other sites More sharing options...
HadeS Posted December 1, 2009 Share Posted December 1, 2009 what make of kit is this?? why you selling?? im interested.. does it need different injectors and ecu to run it Link to comment Share on other sites More sharing options...
mobsta_01 Posted December 2, 2009 Share Posted December 2, 2009 Does it need anything else to do a full conversion? Link to comment Share on other sites More sharing options...
Kirk Posted December 2, 2009 Share Posted December 2, 2009 if your going to do it proper and want to make decent power you will need bigger injectors, thicker HG, piggy back or full standalone ecu, uprated clutch and at least a 5 speed box Link to comment Share on other sites More sharing options...
j_jza80 Posted December 2, 2009 Share Posted December 2, 2009 The manifold looks like one of the cheap OBX ones from American Ebay. The kit looks like it would need at least a piggyback ECU and injectors to be complete. Not sure about plugs although I think the stock fuel pump is good for low boost. Link to comment Share on other sites More sharing options...
StuartW Posted December 2, 2009 Share Posted December 2, 2009 The manifold looks like one of the cheap OBX ones from American Ebay. The kit looks like it would need at least a piggyback ECU and injectors to be complete. Not sure about plugs although I think the stock fuel pump is good for low boost. OBX manifolds are excellent! I had one on my NA/T 440hp no worries Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 2, 2009 Share Posted December 2, 2009 so is this kit worth a bid? as im looking at doing a conversion like this.. what else is needed... anyone?? Link to comment Share on other sites More sharing options...
steve spedd Posted December 2, 2009 Share Posted December 2, 2009 depends what boost levels you want to go to... to use this kit as it is (0.6bar) you will need: piggy back (i woudl suggest Emanage Blue) Wideband AFR 3" exhaust system oil pressure, Oil temp sandwich plate uprated fuel pump oil catch tank few other bits but that would probably get you 350hp ish. but your injector duty cycle will be at its max.... Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 2, 2009 Share Posted December 2, 2009 oh cheers steve prob leave it then and go tt transplant Link to comment Share on other sites More sharing options...
jimbo482 Posted December 6, 2009 Share Posted December 6, 2009 so you would need the above to make it a proper job? Link to comment Share on other sites More sharing options...
Dave Posted December 6, 2009 Share Posted December 6, 2009 if your going to do it proper and want to make decent power you will need bigger injectors, thicker HG, piggy back or full standalone ecu, uprated clutch and at least a 5 speed box how much bhp will the standard n/a auto box take before you need it modifiying or changed ?????????????// if the kit goes for less than 800 quid could be worth a bid will watch this one Link to comment Share on other sites More sharing options...
Swampy442 Posted December 6, 2009 Share Posted December 6, 2009 Box should take 400-450 but you WILL need a beefy oil cooler Link to comment Share on other sites More sharing options...
HadeS Posted December 6, 2009 Share Posted December 6, 2009 £530.00 how could I miss that :/ Link to comment Share on other sites More sharing options...
gordy07 Posted December 6, 2009 Share Posted December 6, 2009 I was going to bid for this but thought it would go for nearer a grand! Link to comment Share on other sites More sharing options...
