Setting up mail on iphone??
TRACIE_LOU
All down to which provider you have.
NTL / Virgin = dire.
Gmail = very good
AOL = good for some reason.
What mail account are you using? If you're using gmail you need to login to it and switch it to IMAP. Where you can use IMAP over POP3.
There is a wizard on the iphone where you just put in your username and password for AOL and GMail and Yahoo iirc.
phone is orange same as home pc??
Is it an "[email protected]" email address??
Tap "Settings"
Tap "Mail, Contacts, Calendars"
Under Accounts tap "Add New" then "Other"
Name = Your Name
Address = Your Email Address
Password = Your Email Address Password
Descrion = Your Choice
It wont be able to auto fill the settings and will bring you to the New Account page.
make sure you select "POP" at the top
Incoming Mail Server = pop.orange.net
Username = your login information
Password = [should already be filled with dots]
Outgoing Mail Server = smtp.orange.net
Username = [leave blank for now]
Password = [leave blank for now]
If you get an error regarding SSL, you should select YES to try again without SSL.
It will now verify and you should be setup correct after this.
