battery relocation and engine earth
hodge
I woldnt have thought an engine would need earthing though. This earth was the only earth that goes to the battery so I guess its for the batteries benifit not for the engine. Aslong as the battery is earthed correctly in the boot i wouldnt have thought there would be a poblem.
It's normal for an engine block to be earthed for all cars, although I'm not exactly sure why. Does the spark need the block to be earthed? Each spark plug has one electrical connection (I think) to it. I guess the remainder of the circuit is made up by earthing the block i.e. electrically connecting it to the -ve battery terminal.
pretty much what stevie b said - block needs to be earthed otherwise you'll get no spark! as the "negative" side of the plug is earthed to the battery via the block and chassis. Same goes for almost any of the electrical circuits - all through the chassis. So when you put the bettery in the boot, just connect a strap from the battery to the chassis. Sorted.
Sorry dude but this is VERY wrong, you really need to make sure the engine is earthed well or it may try to find its own earths through very inconvinient places like throttle cables and wiring looms etc. I would earth the battery in the boot to the chassis using very good quality cable and proper connections, I have 3 seperate engine earths on mine all with very expensive cable and proper terminals, I know a guy forgot to put his engine earth on an M5 BMW and fried loads of electrics/ecu's etc.
Now im really pleased I posted this thanks for the help guys.
I did earth the engine to the chassis on my last build but was looking to save on cabling and wiring, but if it needs to be there then it needs to be there.
Thanks again youve saved me a really big car fire.
Agreed. I had a ghastly electrical problem once and it was caused by the earth strap near the dipstick coming off the engine. All other earths were intact and fine and yet this one missing caused the car to fail to start and all sorts of odd light and gauge behaviour!
-Ian
make sure you earth the wiring loom between the lower runner of the intake . There are 2 earthing points there required. This connects to the ecu . Hand some cars with conversions without these and the ecu went all funny after awhile. replacement units had to be fitted.
As Dude states, you do need it. I have 3 earthing points on my car.
  • 1 year later...
Guest blueangel
when o relocated the battery i earthed the battery in the boot to the body and the original earth in the engine bay i also connected to the body is this ok all seems to be running fine
