Guest Garfy Posted November 30, 2009 Share Posted November 30, 2009 is it a wise thing to do? I came across a flooded road on my way to work today, I drove through it ok, but it made me think, at what height would it start to cause a problem, and are there any low level breathers I should be worred about? Link to comment Share on other sites More sharing options...
AndrewOW Posted November 30, 2009 Share Posted November 30, 2009 If the water covers your headlights, then I'd begin to worry a bit, and if you can see fish in front of you, I think it's too late! Link to comment Share on other sites More sharing options...
Kopite Posted November 30, 2009 Share Posted November 30, 2009 If a fin goes past it might be a problem too Link to comment Share on other sites More sharing options...
AndrewOW Posted November 30, 2009 Share Posted November 30, 2009 If a fin goes past it might be a problem too Have they had nasty floods in Scandinavia too, then? Link to comment Share on other sites More sharing options...
AJI Posted November 30, 2009 Share Posted November 30, 2009 no not a good idea...but depends how deep obviously. The main issue would be brake discs and warping them. If you're discs are hot and they rapidly cool with the water then they can be easily warped. And, to mention the obvious, if water makes it over the bonnet and into the electrics and air filter, the engine bay will suffer. Link to comment Share on other sites More sharing options...
bodilx6 Posted November 30, 2009 Share Posted November 30, 2009 There is an air intake below the headlight. That might result in some issues.. Also, depending on you wiring to sidelights (if you for examplet did them your self, as I wouldn't trust flooding my wirering ) Link to comment Share on other sites More sharing options...
Thorin Posted November 30, 2009 Share Posted November 30, 2009 is it a wise thing to do? Yes of course it is. Link to comment Share on other sites More sharing options...
dangerous brain Posted November 30, 2009 Share Posted November 30, 2009 Ah see I am good in my motor up to about 4 1/2 feet Link to comment Share on other sites More sharing options...
DSK Posted November 30, 2009 Share Posted November 30, 2009 Lets say you have some very heavy rain for several hours and there are some deep ish puddles about 6/7 inches or so developing due to the slope of the road etc then I'd avoid it. It amazes me at how many drive through without a care in the world. Last year when we had some heavy rains, people drove through the puddles whereas I moved the car towards the shallowest part of the puddle (taking up 2 lanes) and crawling through it. Some folks that drove through these puddles that didn't look all that bad ended up grinding to a halt a few yards further up the road Obviously you have to remember that many modern cars have many electrics/sensors etc than can and will be affected by such conditions! Link to comment Share on other sites More sharing options...
Animal Posted November 30, 2009 Share Posted November 30, 2009 The Smart car I had used to be a pain in the arse - there is a small drain hole in the front of the gearbox, low down and if you went through anything deeper than a couple of inches, the gearbox would fill with water. It would run fine until you stopped, then it would not register any movement of the gearstick and you couldn't start the car (semi-auto thing has to be in N to start) until the water drained out which took 2 days. I got stuck 3 or 4 times like that, no matter how gently I went through puddles. Link to comment Share on other sites More sharing options...
Supranature Posted November 30, 2009 Share Posted November 30, 2009 Lets say you have some very heavy rain for several hours and there are some deep ish puddles about 6/7 inches or so developing due to the slope of the road etc then I'd avoid it. It amazes me at how many drive through without a care in the world. Last year when we had some heavy rains, people drove through the puddles whereas I moved the car towards the shallowest part of the puddle (taking up 2 lanes) and crawling through it. Some folks that drove through these puddles that didn't look all that bad ended up grinding to a halt a few yards further up the road Obviously you have to remember that many modern cars have many electrics/sensors etc than can and will be affected by such conditions! exactly, and not to mention the affect on your steering when hittting a couple of inches of water at even low speeds. Drive one-handed at your peril with 245s on the front in/after heavy rain. Link to comment Share on other sites More sharing options...
j_jza80 Posted November 30, 2009 Share Posted November 30, 2009 I once had no choice but to drive through a flood in my old UK spec, the water was above the bottom of the doors, although suprisingly it didn't leak into the cabin. The exhaust sounded interesting! Link to comment Share on other sites More sharing options...
Supranature Posted November 30, 2009 Share Posted November 30, 2009 The Smart car I had used to be a pain in the arse - there is a small drain hole in the front of the gearbox, low down and if you went through anything deeper than a couple of inches, the gearbox would fill with water. It would run fine until you stopped, then it would not register any movement of the gearstick and you couldn't start the car (semi-auto thing has to be in N to start) until the water drained out which took 2 days. I got stuck 3 or 4 times like that, no matter how gently I went through puddles. I cannot, for the life of me, imagine you in a Smart car Link to comment Share on other sites More sharing options...
Animal Posted November 30, 2009 Share Posted November 30, 2009 I cannot, for the life of me, imagine you in a Smart car Lol, yeah, it wasn't really me, but it was useful for a while. Link to comment Share on other sites More sharing options...
stevie_b Posted November 30, 2009 Share Posted November 30, 2009 (edited) If the water covers your headlights, then I'd begin to worry a bit... I'd begin to worry a bit sooner than that. The headlight is where the air intake is, and if you get water pouring into that you're in danger of getting it into the cylinders, and the resulting "hydraulic lock" where the engine seizes up. Obviously, if the water reaches the air intake or any of the ignition-dependent electrics, then it's very risky. Water recess into any of the electrics can be a pain to diagnose, and it can give you some truly bizarre symptoms. I really don't like driving through water. That view might originate from owning Rover Metros in the past. They had exposed HT leads at the front of the engine bay, and the car would splutter and die if they got damp. Sometimes the bloody Metro would start to cough if it merely saw standing water at 30 paces. Edited November 30, 2009 by stevie_b (see edit history) Link to comment Share on other sites More sharing options...
Smallshinyant Posted November 30, 2009 Share Posted November 30, 2009 Just a quick note if you have any fears that the water will be above your exhaust level. Keep the car in a low gear and keep the revs up, so as to make sure that water does not get a chance to get into the pipe. Link to comment Share on other sites More sharing options...
Guest Garfy Posted November 30, 2009 Share Posted November 30, 2009 thanks for advice guys, I think I'll go a different way home Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 30, 2009 Share Posted November 30, 2009 Even if it's over the sills a bit it shouldn't damage the car mechanically if you GO SLOWLY. Diff vent is higher, so is gearbox. Air cleaner will only pull water if it's about half bumper height and I doubt if many would knowingly attempt a crossing like that! Problems start with modded cars with ill conceived air filter set ups. Once the engine inhales water whilst it's running it'll probably hydraulic and be *uggered internally. Link to comment Share on other sites More sharing options...
AlexJames Posted November 30, 2009 Share Posted November 30, 2009 ... we have all seen this pic of me 1000 times before... but I thought id bring it out again... this is as a result of going through a hidden puddle (lake) at speed.... i wont do it again! Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 30, 2009 Share Posted November 30, 2009 The old red eye, nasty, it's caused by effluent contaminated water, isn't it? Link to comment Share on other sites More sharing options...
Lbm Posted November 30, 2009 Share Posted November 30, 2009 Tis the work of the devil himself. Link to comment Share on other sites More sharing options...
Guest Garfy Posted November 30, 2009 Share Posted November 30, 2009 Even if it's over the sills a bit it shouldn't damage the car mechanically if you GO SLOWLY. Diff vent is higher, so is gearbox. Air cleaner will only pull water if it's about half bumper height and I doubt if many would knowingly attempt a crossing like that! Problems start with modded cars with ill conceived air filter set ups. Once the engine inhales water whilst it's running it'll probably hydraulic and be *uggered internally. Thanks Chris, thats exactly the type of answer i was looking for Link to comment Share on other sites More sharing options...
fuldhat Posted November 30, 2009 Share Posted November 30, 2009 Glad we dont have these floods in denmark. I dont even drive mine in the rain.. Link to comment Share on other sites More sharing options...
Guest Garfy Posted November 30, 2009 Share Posted November 30, 2009 this was the flood in question the road was actually closed on the way home Link to comment Share on other sites More sharing options...
Dnk Posted November 30, 2009 Share Posted November 30, 2009 If you have to go through deep water then turn your vehicle around and reverse through the water keeping the revs up, unless your in Range Rover or similar then its shouldnt be a problem Link to comment Share on other sites More sharing options...
