Guest lancemccoo Posted November 29, 2009 Share Posted November 29, 2009 know then guys just wounderd if somone can give me a bit of advice my heater and heater blower, cigeret lighter and also my clock has stoped working can any one give me a clue as to what it way be thanx Link to comment Share on other sites More sharing options...
hadyn Posted November 29, 2009 Share Posted November 29, 2009 It will be a fuse in the drivers footwell area Link to comment Share on other sites More sharing options...
Ian C Posted November 29, 2009 Share Posted November 29, 2009 7.5amp "clock" fuse I think. Link to comment Share on other sites More sharing options...
Guest lancemccoo Posted November 30, 2009 Share Posted November 30, 2009 ive already checked the fuses down there and also looked at the relay in the engine bay has ne1 else got ne other ideas? Link to comment Share on other sites More sharing options...
Ian C Posted November 30, 2009 Share Posted November 30, 2009 Mind the text speak please Well the first thing to do would be to pull the fuse in the footwell and use a multimeter to see if it's actually getting power to it. -Ian Link to comment Share on other sites More sharing options...
kwalker705 Posted December 1, 2009 Share Posted December 1, 2009 Have you checked ALL the fuses ??? Not sure if supra's are the same but .........On my Aristo there's two fuse boxes inside the car. One in the passenger side footwell and one in the drivers side. I blew a fuse and it took me a while to work out that there were a good few other fuses in the other fuse box that I'd not checked. Link to comment Share on other sites More sharing options...
Suprab1 Posted December 5, 2009 Share Posted December 5, 2009 I had very same prob mate for over a year. I changed the cig lighter (one from motorfactors) and mine all stoped working. Also heard phone chargers can cause it if made cheap. Anyway it turned out to be burned out wires behind dash good mechanic/auto elec will fix handy in a couple of hours.I also brought it to toyota they tryed fuses and relay with no joy. Also i brought to 2 auto elec's first and both told me i'd need a new clock as that was burned out aswell (not the case) just a wire or 2 think it was between back of heaters ect to the ignition should only need to clip front of dash not remove all the dash. Good luck i know how you feel. Link to comment Share on other sites More sharing options...
