The-Plethora Posted November 28, 2009 Share Posted November 28, 2009 (edited) Well I have had my supra around 3 weeks now, spent time cleaning everything up, steam cleaned the carpets, fixing stuff that needed fixing and had already booked a painter to sort minor paint defects, All was well until this evening. I left a 40mph zone and entered the national speed limit (long stretch country road), I hadn't even got to 50 when WHACK! the bonnet flys up into the windscreen. The pictures are fairly crappy quality but I would be greatful for any advice on repairs... Side view of the bonnet, you can see how it has split, the paint (in the darkness at least) doesnt look too bad on it Closer up you can see the fibreglass More fibre looking towards the windscreen Windscreen is cracked where the point of the bonnet hit it Underside view of the bonnet, the cracks are in the middle where it flexed as it hit the windscreen It has put a nice dent in the roof as well and I am not even sure what I am going to do with that yet, I will try and get some daylight pictures up. I really dont want to go through my insurance as starting again with no claims is likely to be very expensive. The bonnet is a Do-Luck and is likely very expensive, I know its hard to judge by looking at the terrible photos but do you think it could be sealed and painted again around the split edges? or would I need to buy a complete new bonnet and get it painted? I checked the bonnet catches, mine has 2 catches but not sure if they are standard, the left one is fine but the right one is wedged open so looks like the culprit is the catch and when the wind got under it the left catch flew open. What a shitty day Think I will have to miss out on the rolling road day now as well When this is all fixed the first thing I am going to do is fit a secondary catch! Edit: Added daytime pictures further down the thread also Edited November 30, 2009 by The-Plethora adding pics (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted November 28, 2009 Share Posted November 28, 2009 Thats not good, i`d put a standard bonnet on, get the roof repaired then do a proper job on the screen as if a brick has hit it and get your insurance to sort the screen. Quote Link to comment Share on other sites More sharing options...
L18msy Posted November 28, 2009 Share Posted November 28, 2009 It could be the end of the bonnet hard to tell by the pictures. You could repair the roof as long as your carefull when you are teasing the dents out,you dont want to stretch the metal as it will make the repair bigger and harder to get right. You might also need a set of bonnet hinges as they have been wrenched back on themselves. I would of done it for you if i was closer to you. As above with the screen Quote Link to comment Share on other sites More sharing options...
The-Plethora Posted November 30, 2009 Author Share Posted November 30, 2009 Ok now I have stopped sulking for 5 minutes here are some daytime pictures of the damage, hopefully will give a better idea about if it is possibly repairable or time to go through insurance. A new bonnet is £1096! and will take 8 weeks or so to arrive so I need to consider all options. Drivers side, you can see the windscreen crack hinge and where it went through the rubber weather strip Didnt see this crack until now, it is only on the bottom though. Dent on the roof, doesnt look as bad as when I saw it in the evening for some reason but still probably a tricky fix Top of the bonnet itself looks to be in good condition, no cracks and even the paint seems undamaged Passenger side hinge has damaged the weather strip here also Bonnet seems to have cracked along the seam both sides Underside view of the bonnet damage where it hit the windscreen. Hopefully the pictures help give an idea on repair / replace advice. I want to avoid going back to a stock bonnett if I can. But I understand I am not the only person with a Do-Luck bonnet who has had their catch fail Quote Link to comment Share on other sites More sharing options...
The-Plethora Posted November 30, 2009 Author Share Posted November 30, 2009 Oh yeah it goes without saying but if anyone has hinges or the rubber weather strip going spare please let me know Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted November 30, 2009 Share Posted November 30, 2009 that bonnet can be repaired.to be honest anything thats fibreglass is repairable within reason. Quote Link to comment Share on other sites More sharing options...
The-Plethora Posted November 30, 2009 Author Share Posted November 30, 2009 I have sent "big Al" off with the pictures to see a fibreglass / body repair specialist this afternoon to see what they say, i am a bit worried though as any repair is not going to be as strong as the original. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted November 30, 2009 Share Posted November 30, 2009 a repair will not affect the strength.once its took back down and reglassed it will be as one again,thats the great thing about fibreglass.whhere the two halfs have come apart will get bonded together like it would of been anyway. Quote Link to comment Share on other sites More sharing options...
The-Plethora Posted November 30, 2009 Author Share Posted November 30, 2009 Ah, I am a bit new to all this, so they might pull it into 2 halves entirely and re-seal it all? Would it be 2 gel coat sheets with fibreglass in the middle? It was more the strengthening ribs I was concerned about. I just saw your company in your sig, shame you guys dont do cars! I need to get the bonnet sorted first then i can claim for the windscreen without hurting my no clams, unsure of their position if they heard the bonnett hit it rather than a stone or something. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted November 30, 2009 Share Posted November 30, 2009 Ah, I am a bit new to all this, so they might pull it into 2 halves entirely and re-seal it all? Would it be 2 gel coat sheets with fibreglass in the middle? It was more the strengthening ribs I was concerned about. I just saw your company in your sig, shame you guys dont do cars! I need to get the bonnet sorted first then i can claim for the windscreen without hurting my no clams, unsure of their position if they heard the bonnett hit it rather than a stone or something. we do grp repair which means anything in fibreglass,from boats to bumpers to caravan fronts.i have a top secret front bumper on my own car which was wrecked when i bought it.it wont be pulled in two that would cause more damage.the ribs once repaired will not loose any strength.the gell coat is just a waterproof finishing layer.basicly gell coat laid into the mould first then fibreglassed,when poped out the smooth gel coat becomes the finished surface.just has to be done the other way on a repair Quote Link to comment Share on other sites More sharing options...
Chingy Posted November 30, 2009 Share Posted November 30, 2009 PM'd Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 30, 2009 Share Posted November 30, 2009 Would you not be happy with a stock bonnet that has proper secondary safety fastening, fits properly, and may well be lighter? The roof dent will be the expensive one to fix, get it done whilst the screen is out. Quote Link to comment Share on other sites More sharing options...
Paul Posted November 30, 2009 Share Posted November 30, 2009 Same here, after that's happend I'd rather go back to a stock bonnet, imagine that happening at higher speeds or at a less convenient time Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 30, 2009 Share Posted November 30, 2009 Did the bonnet have bonnet pins in? Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted November 30, 2009 Share Posted November 30, 2009 when I fitted my TSII bonnet i fitted the suicide hook and original mechanism PLUS hood pins. I think thats a must with any aftermarket bonnets. Bad luck mate. The must have been very scary. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted November 30, 2009 Share Posted November 30, 2009 what actualy gives to enable the bonnet to fly up. Quote Link to comment Share on other sites More sharing options...
billy bhoy Posted November 30, 2009 Share Posted November 30, 2009 :faint:man i bet you got the fright of your life! chocolate buttons all over your driver seat!real sorry to see this fella.hope you get it sorted ok!! Quote Link to comment Share on other sites More sharing options...
Kev.O Posted November 30, 2009 Share Posted November 30, 2009 Not good. Sorry to hear this Quote Link to comment Share on other sites More sharing options...
The-Plethora Posted December 1, 2009 Author Share Posted December 1, 2009 Cheers all. Still for those few seconds I probably had an air brake more effective than the one on the veyron:d Just glad it didnt rip off and hit anyone behind or happen on a motorway, at least I was able to bring it to a somewhat controlled stop. I will keep you updated Quote Link to comment Share on other sites More sharing options...
