Steve Posted May 8, 2005 Share Posted May 8, 2005 Have had to change my radiator. Questions are: 1. How much water does the system hold? 2. Is the mix for anti-freeze and water 50/50? Thanks Link to comment Share on other sites More sharing options...
Jake Posted May 8, 2005 Share Posted May 8, 2005 1, None if you use the proper Toyota Forlife coolant. 2, See 1 Link to comment Share on other sites More sharing options...
Jake Posted May 8, 2005 Share Posted May 8, 2005 By the way, you'll need two five litre containers of Forlife Link to comment Share on other sites More sharing options...
Matt T Posted May 8, 2005 Share Posted May 8, 2005 During Summer, you really dont need 50/50 ratio, but might as well as it will save you worrying during the winter nights Link to comment Share on other sites More sharing options...
Steve Posted May 8, 2005 Author Share Posted May 8, 2005 Thanks Jake. Do you know cost of the Forlife stuff? Link to comment Share on other sites More sharing options...
Jake Posted May 8, 2005 Share Posted May 8, 2005 Used to be £14 for 5 litres, might have gone up a little, dunno Link to comment Share on other sites More sharing options...
Steve Posted May 8, 2005 Author Share Posted May 8, 2005 Thanks mate Will go Toyota tomorrow. Link to comment Share on other sites More sharing options...
JustGav Posted May 8, 2005 Share Posted May 8, 2005 Yeah it was 13.65 for 5 litres, £14 near as damn it... Make sure you get the forlife red and not the green.. Gav Link to comment Share on other sites More sharing options...
Lazarus Posted May 8, 2005 Share Posted May 8, 2005 Make sure you get the forlife red and not the green.. Whats the difference? I'm running red anyway, I'm just interested to know. Link to comment Share on other sites More sharing options...
imi Posted May 8, 2005 Share Posted May 8, 2005 RED for J SPEC and GREEN for UK SPEC - according to Toyota. I paid £14-15 for 5 ltrs. Link to comment Share on other sites More sharing options...
Homer Posted May 8, 2005 Share Posted May 8, 2005 Jesus, I paid £8.40 for two 2 litre bottles! Link to comment Share on other sites More sharing options...
JohnA Posted May 8, 2005 Share Posted May 8, 2005 In the summer months I very much like to run 80/20 (as in 80% de-ionised water and 20% pure compatible antifreeze for aluminum heads) I've found that it makes a big difference in cooling efficiency, and the partial draining in October to top up the antifreeze is always beneficial. Link to comment Share on other sites More sharing options...
merckx Posted May 8, 2005 Share Posted May 8, 2005 Anyone know why you should use Forlife stuff instead of normal ethylene glycol based antifreeze? Why Red for J Spec and Green for UK Spec? Also, anyone drained the coolant. How easy is the access to the drain plug on the block? Ta Link to comment Share on other sites More sharing options...
JohnA Posted May 8, 2005 Share Posted May 8, 2005 Anyone know why you should use Forlife stuff instead of normal ethylene glycol based antifreeze? According to the manual, ethylene glycol is fine mate. Forlife is mixed with deionised water, which is important to slow down the buildup of scum inside the water jackets. The majority of garages use tap water, don't forget. How easy is the access to the drain plug on the block? I don't think it's easy even to see that plug, let alone undo it But that's no problem, just undo the rad one, drain what you can, fill with deionised water, run it for a few minutes, then drain again. After a couple of times it will all be pure water. Link to comment Share on other sites More sharing options...
merckx Posted May 8, 2005 Share Posted May 8, 2005 I don't think it's easy even to see that plug, let alone undo it That's pretty typical then! But that's no problem, just undo the rad one, drain what you can, fill with deionised water, run it for a few minutes, then drain again. After a couple of times it will all be pure water. Cheers, that's what I normally do. I've already got some ethylene glycol based antifreeze, no way I'm spending three times as much for the Forlife stuff - waste of money! Link to comment Share on other sites More sharing options...
paul mac Posted May 8, 2005 Share Posted May 8, 2005 I don't think it's easy even to see that plug, let alone undo it But that's no problem, just undo the rad one, drain what you can, fill with deionised water, run it for a few minutes, then drain again. After a couple of times it will all be pure water. the block drain plug is an absolute b*****d to get to, if you are determined to drain the block use the search button and make sure you know exactly where it is, some plasters and bandages might also be usefull, like johnA sez just flush it a couple of times Link to comment Share on other sites More sharing options...
Steve Posted May 8, 2005 Author Share Posted May 8, 2005 Why red for J spec and Green for UK spec? Link to comment Share on other sites More sharing options...
Paul Posted May 8, 2005 Share Posted May 8, 2005 Yeah, why not red for UK? I've just had my UK system changed from red to red again! Paul Link to comment Share on other sites More sharing options...
JustGav Posted May 8, 2005 Share Posted May 8, 2005 I could be speaking out of turn but I was informed a while back... That the difference between red and green was there because of the manufacturing differences in the heads now... and that the green can possible corrode it... Dunno... I've always stuck with the red stuff... Gav Link to comment Share on other sites More sharing options...
Zed Posted May 8, 2005 Share Posted May 8, 2005 I use Toyota Red coolant (not Forlife) also used to use the same in my Celica GT4, no problems whatsoever. I'm sure you should only use red as green is not suitable for higher performance cars. Link to comment Share on other sites More sharing options...
Jake Posted May 8, 2005 Share Posted May 8, 2005 I'm sure you should only use red as green is not suitable for higher performance cars. Ah, of course! Makes perfect sense now! Link to comment Share on other sites More sharing options...
Steve Posted May 8, 2005 Author Share Posted May 8, 2005 Not that debate again!!! Link to comment Share on other sites More sharing options...
Geezabloke Posted May 8, 2005 Share Posted May 8, 2005 Have had Red in mine since i got it..and have refilled with Red. Didnt know there was a difference? Dave Link to comment Share on other sites More sharing options...
Terminator Posted May 8, 2005 Share Posted May 8, 2005 the block drain plug is an absolute b*****d to get to, if you are determined to drain the block use the search button and make sure you know exactly where it is, some plasters and bandages might also be usefull, like johnA sez just flush it a couple of times What are you all moaning about, it is not difficult, you just need a reasonable length extension bar and about 30 seconds of your time. IMHO it should come out as there is a lot of coolant in there. Link to comment Share on other sites More sharing options...
