n/a airbox intake
devan
When i took my headlamp units out the other week, i was looking at the front of the airbox, and noticed that the air intake pipe thing which goes into the stock airbox is in a place where i didnt think it would of been.
I just assumed that the pipe would start at the airbox, and then extend downwards and have its 'intake' end sitting just behind the front bumper air scoop bits.
But instead, the intake part is just sat underneath the headlight, surely the engine would get a better supply of air, if the pipe was exposed to the air directly, like i said, sat just behind a scoop in the front bumper.
I have seen threads on cold air feeds for aftermarket air filters, but just wandered if anybody has tried setting up the stock airbox to a direct air supply/feed thing. A flexible pipe should do the job.
Hope you all understand what i mean lol.
Cheers,
Ash.
  • Replies 51
Like a front mounted intercooler completely covers the radiator but the air finds its way mate
thats because intercoolers and rads are made up from air fins that air passes straight through, thats how there made.
I wouldnt realy say there the same thing.
The intake under the headlamp just gets its air from the side opening on the bumper
Guest suprastar380bhp
x2 The air finds its way.
Suprastar, please refrain from posting misinformed rubish in the technical section.
devan, the reason for the air intake positions is due to cold air source, nothing more. The key to performance is having a cold air source which is why the vents for the filter box are outside the engine bay.
The reason there isn't a direct source from an exposed area is due to the crap that would get *forced* into the intake. It needs to come from a clean air source out of impact range hence the stock positions of the two intakes.
Homer, i understand about the cold air source, i just wandered why the intake wasnt directly behind the air scoops in the front bumper, rather than being covered up by the headlamp.
But its all good, im not going to be doing anything about it i dont think, just a question i had in my mind.
Cheers.
Cheers.
See edit above. Direct forced air intake is a *very* bad idea for a road car, unless you want to change the filter evey time it rains ;)
im sure the verry inteligent designers at toyota thaght long and hard about how the engine would breath and would not make intakes that would starve the engine of air.
the biggest problem with haveing a large feed behind a vent is the possibility of large items blocking the feed. plastic bags ect
edit , beaten to it again,
Sorry just m life winding me up
he is very good at it
I was doing ok
He new what he was doing
well talk sence..... saying air finds its way to the intake behind the headlamp is the same way air finds its way to a rad with a FMIC is utter crap cause it doesnt
OMG HE IS NA I went off subject SORRY
I AM SO SORRY
SORRY M LIFE SORRY
sorry
[quote=suprastar380bhp;2585220
i didnt say that!
he has edited his words!
BLOCKED! ignored
Edited by suprastar380bhp (see edit history)
but what im saying is it doesnt find its way, the engine sucks it in from the side opening from the bumper so it doesnt realy find its way
__________________
Dude - when the green light drops the bull$#@! stops
Ryan.G - All High HP cars are Sluts. When you drive/ride them its bloody great but when they start not doing as they are told and money is needed to be spent it lives up to its name!
__________________
point being? like i just said i added 1 word. Im pretty sure everyone else understood it
YOU DIDNT!!! how have you flipped it round, you telling everyone that you get air from the side port under the light when a fmic is installed to get air to the radiator
if you get away with it your quite clever
The key word here from your post is sucks. Both in the way that an engine works and your understanding of it.
The induction areas are those that are in an area that is out of the way of impact but crucially under positive pressure.
No measurable postive performance will happen after moving the induction area to one in a forced airflow. It'll only result in forgien objects getting sucked into the filter.
The headlight removal only works for massive HP single/twin cars due to the fact they are only doing a short run and need HUGE airflow.
I was doing ok
Front Mounted Intercooler
An intercooler is an air to air heat exchanger. The intake air going into the engine flows through it and is cooled down by air passing over the intercooler like a normal car radiator.
In that quote did i use any of the words against me
