MIL Light under hard acceleration
devan
  • 6 months later...
I dont think that code will have anything to do with the MIL light. if the car had a crank sensor fault it wouldnt start.
I have a crank sensor fault on mine (error code 13) but its been starting up no problems and driving ok.
I would double check the brake fluid level as already pointed out - the sensor is very very sensitive so make sure your fluid is topped up to the max level, verifying with the cap off as it's hard to determine just looking at the resevoir itself.
Cheers,
Brian.
