Dragonball Posted November 7, 2002 Share Posted November 7, 2002 Sorry to re-hash this one - but cant find it in search Just fitted a manual boost gauge - but not sure if it working OK On idle it falls to approx -0.7 - and I really haven't got it past +0.5 on medium acceleration How do I check - and what are anyone else's manual readings? Many thanks Paul Quote Link to comment Share on other sites More sharing options...
Billy Posted November 7, 2002 Share Posted November 7, 2002 That sounds about right to me i have got a de cat and nur spec r i get about the same at idle and about 0.8 bar under medium acceleration Quote Link to comment Share on other sites More sharing options...
ChrisR Posted November 7, 2002 Share Posted November 7, 2002 Hi Paul, Ideally you will need to get a max output reading on the gauge, my Supra is just Decatted with stock cat back exhaust and am outputting 0.9 BAR, 13 PSI and once i get a Blitz Nur Spec R i will aim for 1.2 BAR 18 PSI. It may go higher than that which means that a restrictor ring will need fitting. As billy says it depends on each car. Regards Chris Quote Link to comment Share on other sites More sharing options...
Thorin Posted November 7, 2002 Share Posted November 7, 2002 I asked the same thing when I fitted mine. In my ignorance I'd assumed that the gauge should sit at zero on idle (and not at -0.7 like it does). On full acceleration it gets to 0.8 (or maybe very slightly higher). Quote Link to comment Share on other sites More sharing options...
Dragonball Posted November 8, 2002 Author Share Posted November 8, 2002 Thanks guys - yes got it up to 0.8/0.9 on a heavy acceleration Normal about 0.5 So seems ok Cheers Paul:cool: Quote Link to comment Share on other sites More sharing options...
