Guest EasyRider3708 Posted November 25, 2009 Share Posted November 25, 2009 Hi there. Can I first just say what a great forum this is, very easy to use and it seems quite a lot of knowledgeable people on here. Now I'm hoping you guys can help me with a query...my question is simply can you use the sequential system to run both a SC and a large turbo? Do you TT owners have an electronic wastegate to switch off the smaller turbo when the larger one is in use? Any help or advice would be most appreciated. Jay Quote Link to comment Share on other sites More sharing options...
Jake Posted November 25, 2009 Share Posted November 25, 2009 (edited) Hi, I'm not sure I understand the question. By "SC" do you mean Supercharger? If so, then no, that's not how superchargers work. TTs do not have an elec wastegate. Both turbos are the same size, there isn't a larger and smaller one. When the 2nd turbo is in use the first turbo is also still working. Edited November 25, 2009 by Jake Add a bit more info (see edit history) Quote Link to comment Share on other sites More sharing options...
edge Posted November 25, 2009 Share Posted November 25, 2009 A large turbo also requires a piggy back ecu or standalone Quote Link to comment Share on other sites More sharing options...
Guest EasyRider3708 Posted November 25, 2009 Share Posted November 25, 2009 Sorry for confusion guys. Basically I'm toying with the idea of fitting a large turbo (GT35) on a different car (non supra) and obviously this is going to mean a fair amount of lag. My thinking was to use the sequential system if possible, out of a TT and have a supercharger that works up to say 4000rpm. Could I not use the system off a Supra to do this or will something off a 300ZX work? The only other solution would be to use something off one of them SC-TC Golfs but I thought I would explore this avenue first. BTW I do have all the supporting mods, just a case of whether it is possible to make this work. Quote Link to comment Share on other sites More sharing options...
garethr Posted November 25, 2009 Share Posted November 25, 2009 (edited) Leaving aside all the other issues...... Twin screw/positive displacement or centrifugal supercharger? I would guess the former, in which case, production superchargers (as on Mercs) usually have electronic clutches and bypass valves. Edited November 25, 2009 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
edge Posted November 25, 2009 Share Posted November 25, 2009 Would nitrous not be an option? less hassle? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted November 25, 2009 Share Posted November 25, 2009 I think the problem is that the supra uses one turbo and then switches to two. And not one and then the other. It also does a lot of fancy things like feeding air to the 2nd turbo just before it is "turned on" iirc. Someone wrote a great article somewhere but i have no idea where it is. So i doubt your plan would work. Someone in the usa has developed a kit with aftermarket turbos. But i think they are both still the same size? And its ludicrously expensive. I havent even seen one yet. lol Edit - Here you go http://www.boostlogic.com/xcart/product.php?productid=160&cat=9&page=1 but like i say. i dont think it uses anything stock. Quote Link to comment Share on other sites More sharing options...
paul mac Posted November 26, 2009 Share Posted November 26, 2009 Sorry for confusion guys. Basically I'm toying with the idea of fitting a large turbo (GT35) on a different car (non supra) and obviously this is going to mean a fair amount of lag. My thinking was to use the sequential system if possible, out of a TT and have a supercharger that works up to say 4000rpm. Could I not use the system off a Supra to do this or will something off a 300ZX work? The only other solution would be to use something off one of them SC-TC Golfs but I thought I would explore this avenue first. BTW I do have all the supporting mods, just a case of whether it is possible to make this work. gawd this would be horrendously complex, dont forget all the control solenoids need controlling by an ecu as well, if your trying to run an SC with a turbo i would start from scratch there are cars out there that do this, i would have a look at them rather than the supra system Quote Link to comment Share on other sites More sharing options...
AndyT Posted November 26, 2009 Share Posted November 26, 2009 I think the problem is that the supra uses one turbo and then switches to two. And not one and then the other. It also does a lot of fancy things like feeding air to the 2nd turbo just before it is "turned on" iirc. Someone wrote a great article somewhere but i have no idea where it is. So i doubt your plan would work. Someone in the usa has developed a kit with aftermarket turbos. But i think they are both still the same size? And its ludicrously expensive. I havent even seen one yet. lol Edit - Here you go http://www.boostlogic.com/xcart/product.php?productid=160&cat=9&page=1 but like i say. i dont think it uses anything stock. Some great work here. http://www.max-boost.co.uk/max-boost/supra/turbo.htm Quote Link to comment Share on other sites More sharing options...
