DodgyRog Posted March 7, 2010 Share Posted March 7, 2010 Looking good mate, looks like I need to find the Power steering pump really soon. I will see if I can just get the bolt bit that was damaged on yours if nothing else and we can swap them back over then, as I dont think there was anything wrong with mine anyway. Think it was just an air lock in the end Link to comment Share on other sites More sharing options...
barneybrendan Posted March 7, 2010 Author Share Posted March 7, 2010 Looking good mate, looks like I need to find the Power steering pump really soon. I will see if I can just get the bolt bit that was damaged on yours if nothing else and we can swap them back over then, as I dont think there was anything wrong with mine anyway. Think it was just an air lock in the end dont worry about that part as i damaged it anyway.i will see if anybody has the bit on here. Link to comment Share on other sites More sharing options...
DodgyRog Posted March 7, 2010 Share Posted March 7, 2010 dont worry about that part as i damaged it anyway.i will see if anybody has the bit on here. I was going to give Stuart at Teignmouth a shout tomorrow, he said he had knackered a few pumps, so was hoping he hadn't bined them, I am happy to swap them back over, just let me know when. I am doing a Gearbox and Diff fluid change next week and sorting the Cat out, so fingers crossed the squeky/screech noise goes Link to comment Share on other sites More sharing options...
barneybrendan Posted March 7, 2010 Author Share Posted March 7, 2010 I was going to give Stuart at Teignmouth a shout tomorrow, he said he had knackered a few pumps, so was hoping he hadn't bined them, I am happy to swap them back over, just let me know when. I am doing a Gearbox and Diff fluid change next week and sorting the Cat out, so fingers crossed the squeky/screech noise goes ok mate if he has got any i need the copper double washer thing aswell.Just let me know and i can run up or unless you popping down.Up to you mate about swapping them back over. Link to comment Share on other sites More sharing options...
barneybrendan Posted March 7, 2010 Author Share Posted March 7, 2010 whith the charger squared up the belt becomes nice and tight,so my question is am i going to need a tensioner in there as its a small belt.If so would i be better off getting a slightly longer belt. please give opinions and reasons behind them,cheers. Link to comment Share on other sites More sharing options...
barneybrendan Posted March 10, 2010 Author Share Posted March 10, 2010 another sunny day ,so i descided to weld the chassis leg back up.managed to do another support for the charger bracket.Now need some box section to make a spacer coming off the back of the charger so throttle body clears the engine mount. Just waiting for the clutch to turn up now so the engine can go back in the car. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 10, 2010 Share Posted March 10, 2010 Neat sheet steel chassis leg welding, I am impressed Do you do VIN numbers.... Link to comment Share on other sites More sharing options...
barneybrendan Posted March 10, 2010 Author Share Posted March 10, 2010 Neat sheet steel chassis leg welding, I am impressed Do you do VIN numbers.... ssshhhh;) Link to comment Share on other sites More sharing options...
Matt H Posted March 10, 2010 Share Posted March 10, 2010 Fantastic looking work on the weld Link to comment Share on other sites More sharing options...
barneybrendan Posted March 11, 2010 Author Share Posted March 11, 2010 had to make some flanges and adapter for the bypass valve today,as it fouled the engine mount with the charger on its side.the inlet port on the charger is rectangle so had to make it out of box section. the bypass valve now needs the alloy tube welded on the fitting so it can be welded to the out side of the charger.Need to get the pipe sorted out for the intake so i can sort out where to put the throttlebody,but think this will have to wait until the engine is back in the car. Going to clean the box section up tomorrow and paint it along with the main charger bracket. Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 11, 2010 Share Posted March 11, 2010 im looking forward to seeing this thing in action. Link to comment Share on other sites More sharing options...
barneybrendan Posted March 11, 2010 Author Share Posted March 11, 2010 im looking forward to seeing this thing in action. its getting a lot closer than when i first had the idea in my head.Shouldnt be too long after the clutch arrives. Link to comment Share on other sites More sharing options...
barneybrendan Posted March 18, 2010 Author Share Posted March 18, 2010 i now have my clutch but what a change in the weather:(.going to have to wait for the next dry day now to get the engine back in the car.There isnt really much i can do until the engine is in now. Link to comment Share on other sites More sharing options...
ScottC Posted March 18, 2010 Share Posted March 18, 2010 Once you have the engine back in will you have much more to do? Link to comment Share on other sites More sharing options...
barneybrendan Posted March 18, 2010 Author Share Posted March 18, 2010 Once you have the engine back in will you have much more to do? sort out the throttle body position fmic pipes need making battery needs to go in the boot wire up electric fans wire up injector resistor then off for mapping plus anything ive forgotten. Link to comment Share on other sites More sharing options...
ScottC Posted March 18, 2010 Share Posted March 18, 2010 Looks like there is light at the end of this long tunnel. Link to comment Share on other sites More sharing options...
barneybrendan Posted March 18, 2010 Author Share Posted March 18, 2010 Looks like there is light at the end of this long tunnel. i hope so its taking long enough.mainly down to the weather and a bit of spare cash now. Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted March 18, 2010 Share Posted March 18, 2010 you will need a tensioner for the belt for the charger, maybe you can make the bracket slightly adjusable? Link to comment Share on other sites More sharing options...
barneybrendan Posted March 18, 2010 Author Share Posted March 18, 2010 you will need a tensioner for the belt for the charger, maybe you can make the bracket slightly adjusable? i have a manual tensioner that needs a bracket made for it,but going to see what its like without it first.At the moment i can only just walk the belt on and its about perfect tension,bare in mind the belt will get tighter as it spins. Link to comment Share on other sites More sharing options...
Smallshinyant Posted March 18, 2010 Share Posted March 18, 2010 i have a manual tensioner that needs a bracket made for it,but going to see what its like without it first.At the moment i can only just walk the belt on and its about perfect tension,bare in mind the belt will get tighter as it spins. i never knew that. i thought it would just get looser as the pulleys spun up. But thats why your building a supercharged na and not me Getting excited now as its getting closer to being turned over. Keep it up, i have ordered some good weather so you can get it back in the car this weekend. Link to comment Share on other sites More sharing options...
barneybrendan Posted March 19, 2010 Author Share Posted March 19, 2010 i never knew that. i thought it would just get looser as the pulleys spun up. But thats why your building a supercharged na and not me Getting excited now as its getting closer to being turned over. Keep it up, i have ordered some good weather so you can get it back in the car this weekend. just checked the forecast rain for the next 5 days ,dont think your order went through. i would of thought it would get looser,but all info leads to it getting tighter even sent eaton an email and they confirmed this. Link to comment Share on other sites More sharing options...
Smallshinyant Posted March 19, 2010 Share Posted March 19, 2010 just checked the forecast rain for the next 5 days ,dont think your order went through. i would of thought it would get looser,but all info leads to it getting tighter even sent eaton an email and they confirmed this. Stupid weather. well maybe next weekend Link to comment Share on other sites More sharing options...
wile e coyote Posted March 19, 2010 Share Posted March 19, 2010 Should be able to give you a hand to get it in one eve next week mate Link to comment Share on other sites More sharing options...
Smallshinyant Posted March 19, 2010 Share Posted March 19, 2010 Just a thought, who the hell is gonna do the mapping? where do you even start when going to a supercharger? Link to comment Share on other sites More sharing options...
wile e coyote Posted March 19, 2010 Share Posted March 19, 2010 afr are going to be mapping it Link to comment Share on other sites More sharing options...
