barneybrendan Posted July 3, 2011 Author Share Posted July 3, 2011 fitted the ridox front bumper today to give me a better idea of what its going to look like.It was pretty good fit. Link to comment Share on other sites More sharing options...
safcdixon Posted July 3, 2011 Share Posted July 3, 2011 looks like it will be nice when its painted fella nice work are you lowering the front seems to be riding a tad high? Link to comment Share on other sites More sharing options...
Blackie Posted July 3, 2011 Share Posted July 3, 2011 Looking good Barn Link to comment Share on other sites More sharing options...
ripped_fear Posted July 3, 2011 Share Posted July 3, 2011 coming together nicely! Link to comment Share on other sites More sharing options...
barneybrendan Posted July 3, 2011 Author Share Posted July 3, 2011 i only just let it down of axle stands,been up in the air for a week or so. Link to comment Share on other sites More sharing options...
DodgyRog Posted July 3, 2011 Share Posted July 3, 2011 Whats the sail on the back all about;) Link to comment Share on other sites More sharing options...
barneybrendan Posted July 3, 2011 Author Share Posted July 3, 2011 DodgyRog said: Whats the sail on the back all about;) its something you need when you are forced induction and not run by elastic band. Link to comment Share on other sites More sharing options...
DodgyRog Posted July 3, 2011 Share Posted July 3, 2011 Mine just keeps getting heavier anyway;), so I am starting to think even when I go TT Bpu it will still be slow:D How close are you to having it running now, I know you are still in need of the Ridox skirts, but engine wise are you close Link to comment Share on other sites More sharing options...
barneybrendan Posted July 3, 2011 Author Share Posted July 3, 2011 just got to make a couple flanges ,so its really just a good day welding /fabricating and i should be done.Be interesting to get it on a dyno again to see what difference i have made since AFR mapped it the first time. Link to comment Share on other sites More sharing options...
DodgyRog Posted July 3, 2011 Share Posted July 3, 2011 So close, can't wait to see this chewing tyres when are you starting with the spraying or are waiting for the skirts first Link to comment Share on other sites More sharing options...
barneybrendan Posted July 3, 2011 Author Share Posted July 3, 2011 just waiting for the paint to come apparently then he can crack on. Link to comment Share on other sites More sharing options...
bradleyh_15 Posted July 3, 2011 Share Posted July 3, 2011 I can't wait to hear this in the flesh! You making suprapod? Link to comment Share on other sites More sharing options...
barneybrendan Posted July 3, 2011 Author Share Posted July 3, 2011 hope so.The car should be at a stage where it will be ok to run. Link to comment Share on other sites More sharing options...
bradleyh_15 Posted July 3, 2011 Share Posted July 3, 2011 Good stuff! I bet you can't wait to finish the project and reap the rewards! Link to comment Share on other sites More sharing options...
barneybrendan Posted July 3, 2011 Author Share Posted July 3, 2011 bradleyh_15 said: Good stuff! I bet you can't wait to finish the project and reap the rewards! Its my fault a lot of it for constantly changing things around.I should of been happy with the results at AFR but no i had to go and change things again.Plus if i had left the body work as it was i would be driving it around now.In answer to reaping ay rewards . I cant frigging wait to hammer it around my streets. Link to comment Share on other sites More sharing options...
Blackie Posted July 4, 2011 Share Posted July 4, 2011 DodgyRog said: Whats the sail on the back all about;) barneybrendan said: its something you need when you are forced induction and not run by elastic band. Lol Link to comment Share on other sites More sharing options...
barneybrendan Posted July 4, 2011 Author Share Posted July 4, 2011 Damn hot on the drive today,but cracked on a bit more.Fitted the st205 throttle cable,had to file the hole going through the bulk head bigger as the adjuster nuts on the st cable are larger than the na ones.The bypass valve is now fitted properly andis a direct feed.the intake pipe is now held tight with a bracket going to the intake runners.Not sure on the q45 throttle body at the moment.Going to look for something the same size as the na 3" but needs to be compact like the q45 one.The spare na throttle body is with the engineers to get the holes bunged up. Link to comment Share on other sites More sharing options...
David P Posted July 4, 2011 Share Posted July 4, 2011 Have you room to use a Lexus V8 72mm t.b, you would then have plug & play TPS. Link to comment Share on other sites More sharing options...
barneybrendan Posted July 4, 2011 Author Share Posted July 4, 2011 how long are they as that is my limiting factor.The q45 one is perfect size but just a little too big a bore for the minute.. Link to comment Share on other sites More sharing options...
David P Posted July 4, 2011 Share Posted July 4, 2011 (edited) I can't nip out with a tape measure, because it's 20 miles away. The butterfly is 72mm yet the body is shorter in length because without an I.C.V. There are plenty of pics of it in my project thread, even one next to an N/A t.b. Here's a pic. Edited July 4, 2011 by David P (see edit history) Link to comment Share on other sites More sharing options...
Aero-M Posted July 4, 2011 Share Posted July 4, 2011 barneybrendan said: My mirrors arrived today so i thought i would go and fit them.The passenger side fits really well,but the drivers side has a gap that i cant seem to get rid of.Every time ai tighten the bolts it pulls the mirror away from the pillar.Plus the original hole in the door shows slightly at the bottom.These are used mirrors so should fit perfectly. All the ganador mirrors are supposidly like that, mine are and so are others I have seen. Pita, as mine really annoys me, just looks odd. Link to comment Share on other sites More sharing options...
David P Posted July 4, 2011 Share Posted July 4, 2011 I have just remembered it's on the car, excuse my blonde moment. 5 1/2" long Barney. Link to comment Share on other sites More sharing options...
barneybrendan Posted July 4, 2011 Author Share Posted July 4, 2011 Just seen the pic of them both together going to see if i can borrow one off somebody now.I f i do i will be giving you a shout for what pipes connected where on it. Link to comment Share on other sites More sharing options...
barneybrendan Posted July 10, 2011 Author Share Posted July 10, 2011 The stripped down na throttle body is now in place. Link to comment Share on other sites More sharing options...
David P Posted July 14, 2011 Share Posted July 14, 2011 Your inbox is stuffed. Link to comment Share on other sites More sharing options...
