David P Posted May 9, 2011 Share Posted May 9, 2011 (edited) Here's a link to a page full of same spec products, you have learned the gold plated prices sometimes asked, look around. http://www.google.co.uk/search?sourceid=chrome&ie=UTF-8&q=Multipurpose%2CExtreme-PressureLithium+ComplexGrease#hl=en&sa=X&ei=plDITZjiJMWY8QOvodn2Bw&ved=0CCAQBSgA&q=Multipurpose,Extreme-Pressure+Lithium+Complex+Grease&spell=1&fp=a19d57c9b1bb4a83&biw=1280&bih=685 Morris Lubricants, 400g cartridge £3.95 inc P&P beat that. Edited May 9, 2011 by David P (see edit history) Link to comment Share on other sites More sharing options...
barneybrendan Posted May 9, 2011 Author Share Posted May 9, 2011 is the morris stuff the same as kendall then Link to comment Share on other sites More sharing options...
barneybrendan Posted May 11, 2011 Author Share Posted May 11, 2011 My mirrors arrived today so i thought i would go and fit them.The passenger side fits really well,but the drivers side has a gap that i cant seem to get rid of.Every time ai tighten the bolts it pulls the mirror away from the pillar.Plus the original hole in the door shows slightly at the bottom.These are used mirrors so should fit perfectly. Link to comment Share on other sites More sharing options...
David P Posted May 11, 2011 Share Posted May 11, 2011 It's the same spec, how much is the Kendal Blue? The Beastie is getting whiter one piece at a time and with those little sticky out ears, it has grown a canine expression. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 11, 2011 Author Share Posted May 11, 2011 £8 but then £28 delivery from the states. Link to comment Share on other sites More sharing options...
David P Posted May 11, 2011 Share Posted May 11, 2011 I am sure it turned up in UK when I googled it. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 11, 2011 Author Share Posted May 11, 2011 i will try again then. Link to comment Share on other sites More sharing options...
David P Posted May 11, 2011 Share Posted May 11, 2011 I bet the Hot-rod Drag Race shops have it. Link to comment Share on other sites More sharing options...
Supra Gaz Posted May 15, 2011 Share Posted May 15, 2011 Keep hacking away at this mate, your an inspiration to everyone who looks at their car with a spanner in hand and thinks 'I wish I had the balls to do it myself'. It will be brilliant and individual when done Link to comment Share on other sites More sharing options...
barneybrendan Posted May 15, 2011 Author Share Posted May 15, 2011 Keep hacking away at this mate, your an inspiration to everyone who looks at their car with a spanner in hand and thinks 'I wish I had the balls to do it myself'. It will be brilliant and individual when done Cheers mate its been a slow old grind.Will be going santapod with it even if its not mot'd.Going to take a couple of smaller pulleys and belts with me aswell to up the boost a bit if needed. Link to comment Share on other sites More sharing options...
Supra Gaz Posted May 15, 2011 Share Posted May 15, 2011 Cheers mate its been a slow old grind.Will be going santapod with it even if its not mot'd.Going to take a couple of smaller pulleys and belts with me aswell to up the boost a bit if needed. That's brilliant to hear dude, it will be good to see this thing blast up those straights! Link to comment Share on other sites More sharing options...
barneybrendan Posted May 16, 2011 Author Share Posted May 16, 2011 Been to the bearing shop today and they can get me the 2 rear needle bearings,the snout seal,the front and rear snout bearings and the right grease i need for £62,i then have to get the supercharger oil from somewhere.I didnt think that was too bad as the grease is £16 so could knock that off and source elsewhere.i have been told that a mini club in the uk stocks the oil so will try and find them to see how much it is. Link to comment Share on other sites More sharing options...
garethr Posted May 16, 2011 Share Posted May 16, 2011 Here's one supplier of supercharger oil http://www.minimaniauk.co.uk/web/Item/NME7250/InvDetail.cfm or in the USA http://www.zzperformance.com Link to comment Share on other sites More sharing options...
barneybrendan Posted May 16, 2011 Author Share Posted May 16, 2011 (edited) Thats the mini one i just found,and zzperformance do all the service parts aswell.Cheers for taking the time to look aswell looks like it still has to come from usa on the mini mania site Edited May 16, 2011 by barneybrendan (see edit history) Link to comment Share on other sites More sharing options...
barneybrendan Posted June 3, 2011 Author Share Posted June 3, 2011 The supercharger now sounds sweet out of the car,replaced rear needle bearings,snout front and rear bearings and snout seal.sealed the body with loctite and filled up with some fresh oil.I was told that i would need a press to remove and fit the snout bearings .Well i havnt and only have a selection of alloy bearing drifts and made some thick washers to spread the weight across the bearing for refitting then used a heavy duty clamp and some deep impact sockets to press them in fully from either side at the same time. Waiting for my new pulley and hub to arrive now so i can refit the charger . Link to comment Share on other sites More sharing options...
barneybrendan Posted June 11, 2011 Author Share Posted June 11, 2011 (edited) Had some inserts made to make the 50mm spacers hub sentric,Just need a little bit of reeming out and they will be perfect.Big thanks to Al (Zippy tt) for making them for me.I have borrowed a q45 throttlebody to put before the charger now and have removed the throttle butterfly and linkage from a spare na throttle body.I am planning on leaving the na throttle body case in place with the idle control valve and use the q45 tps.I need to get 2 blankers and have the holes tapped where the butterfly bar came through the case.Next i need to refit the charger so i can make a bracket to hold the nissan throttlebody and make an adaptor to take the bypass valve which will sit behind the throttle body now. Edited June 11, 2011 by barneybrendan (see edit history) Link to comment Share on other sites More sharing options...
barneybrendan Posted June 11, 2011 Author Share Posted June 11, 2011 Just spent another fiew hours sanding and filling the ridox front bumper,all these damn stone chips are driving me mad ,i'd rather the bumper was just broken in half as that would be easier. Link to comment Share on other sites More sharing options...
Dyer864 Posted June 11, 2011 Share Posted June 11, 2011 getting there barny good work, wont be long the hard slog will be well worth it ! Link to comment Share on other sites More sharing options...
David P Posted June 11, 2011 Share Posted June 11, 2011 One of those Yank N/A n/s intakes would plumb nicely into the equation. Link to comment Share on other sites More sharing options...
barneybrendan Posted June 12, 2011 Author Share Posted June 12, 2011 One of those Yank N/A n/s intakes would plumb nicely into the equation. It would look nice ,i did have a manifold like that and sold it . Link to comment Share on other sites More sharing options...
barneybrendan Posted June 27, 2011 Author Share Posted June 27, 2011 new pulley arrived today.Was real happy until i fitted it as it wasnt machined properly.The recess on the pulley needed taking out a bit more as it didnt sit properly and the pulley was way out.Just waiting to see if they will give me back what it just cost to fix it.I have gone from a 4" pulley to a 3.4",plus you will notice that it is an 8 rib pulley .The reason for the wider pulley is i am having another crank pulley made which will enable me to change the supercharger crank pulley aswell. Link to comment Share on other sites More sharing options...
David P Posted June 27, 2011 Share Posted June 27, 2011 (edited) I have recently also learned that pulleys can be a wind-up, the one I had copied for the supercharger has been made without a belt lip. Upgrading to an 8-rib is a good idea whilst swapping pulleys and you need only two wheels and one idler, if I have to upgrade, I will need four wheels and three idlers. Edited June 29, 2011 by David P (see edit history) Link to comment Share on other sites More sharing options...
barneybrendan Posted June 28, 2011 Author Share Posted June 28, 2011 well things are changing all the time ,ive now repositioned the bypass valve is now going to live just after the throttlebody.Not a lot of room around the charger now.The q45 throttle body will fit nicely in the space i have now with a 90 degree silicone coupler going down through the inner arch to the cone filter.I need to make a flange to fit up against the throttlebody now to connect it to the hard intake pipe.I have got my st205 throttle cable ready. Link to comment Share on other sites More sharing options...
David P Posted June 29, 2011 Share Posted June 29, 2011 (edited) That Q45 TB has a 3 wire TPS and the Supra has 4. I have a TPS from an MX6 which is the same size, fit and plug & play with with Supra loom, but works the other way around, same as the Q45. Would you like it to play with? Edited June 30, 2011 by David P (see edit history) Link to comment Share on other sites More sharing options...
barneybrendan Posted June 29, 2011 Author Share Posted June 29, 2011 There is another plug that fits on aswell.was fitted to a supra before as its not mine and i am just borrowing it better leave as it is for the time being.Cheers though. Link to comment Share on other sites More sharing options...
