Chris Wilson Posted December 18, 2009 Share Posted December 18, 2009 Can you explain in more depth about the oil filter area clearance issues? I am pretty good at sorting these as I come across this a lot when road car engines are adapted to go into race car chassis's. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 18, 2009 Author Share Posted December 18, 2009 Can you explain in more depth about the oil filter area clearance issues? I am pretty good at sorting these as I come across this a lot when road car engines are adapted to go into race car chassis's. i have 6cm clearance from the block where the original filter housing mounted.what i need is almost like a sandwich plate to bolt to the block with 2 pipes coming off to the oil filter relocator. a couple of the pics show the sort of clearance issue i have. Quote Link to comment Share on other sites More sharing options...
Kirk Posted December 18, 2009 Share Posted December 18, 2009 im impressed i must admit. Many people have undertaken this sort of project and failed but this 1 actualy looks quite promising, hell the supercharger actualy fits in a reasonably sensible place nice work Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 18, 2009 Author Share Posted December 18, 2009 im impressed i must admit. Many people have undertaken this sort of project and failed but this 1 actualy looks quite promising, hell the supercharger actualy fits in a reasonably sensible place nice work i cant understand why nobody has thought of putting it here,it just made perfect sense to me just had to find the right model m90. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 18, 2009 Share Posted December 18, 2009 Good work so far. Im not normally a fan of trial and error on the Supra, but at least you are making progress. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 18, 2009 Share Posted December 18, 2009 My first comment on this post, and it is that i find this a refreshing change to, and partly due to the recent crop of " I'm going to get such and such power" or "I'm going to finish this by" type threads;) You seem to have actually given the conversion a lot of thought, and gone about it in a methodical if somewhat trial and error way, you gladly take sensible advice and criticism and admit to making mistakes, without chucking toys, and so far i can't say that anything you have posted has given me cause to question methods or technicality's (much:innocent:) So i look forward to seeing the end results:thumbs: Subscribed! Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 18, 2009 Author Share Posted December 18, 2009 as this is a learning curve im sure on some aspects people have better ideas .i take critisism constructivly because i view it as help.the thing is you can spend so much time on something that you can become blinded by what needs doing correct.no doubt i will be making more mistakes but hopefully that will help others not to make the same ones. Quote Link to comment Share on other sites More sharing options...
Wez Posted December 18, 2009 Share Posted December 18, 2009 im impressed i must admit. Many people have undertaken this sort of project and failed but this 1 actualy looks quite promising, hell the supercharger actualy fits in a reasonably sensible place nice work I agree, keep up the good work Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 18, 2009 Share Posted December 18, 2009 i have 6cm clearance from the block where the original filter housing mounted.what i need is almost like a sandwich plate to bolt to the block with 2 pipes coming off to the oil filter relocator. a couple of the pics show the sort of clearance issue i have. I may have something suitable, I have locked up shop for the night, but I'll try and get a photo over the weekend. It's an adaptor to remote mount the oil filter, and it's quite slim. The issue will be where the pipes come out of it. Are you stripping the engine before it's run? If so drill and tap the holes in the filter area of the block to take pipe adaptors coming off at suitable angles. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 18, 2009 Author Share Posted December 18, 2009 I may have something suitable, I have locked up shop for the night, but I'll try and get a photo over the weekend. It's an adaptor to remote mount the oil filter, and it's quite slim. The issue will be where the pipes come out of it. Are you stripping the engine before it's run? If so drill and tap the holes in the filter area of the block to take pipe adaptors coming off at suitable angles. cheers.wasnt planning on stripping the engine.wanted to run it to see what it does,then rebuild the other one.i did think of tapping the hole out that returns to the sump as a last resort.but if i could get some sort of slim fitting ,that would make it more user friendly.idealy it needs to be like the part that screws to the housing for remote fitting.but have a bolt through it instead of it screwing on.if i can only get something that pushes the charger over more then was thinking of half mooning the chassis like we used to do on the old fiestas when fitting a 5 speed box. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 18, 2009 Share Posted December 18, 2009 Neither hole returns to the sump, one is the feed from the outlet side of the oil pump, the other feeds into the main oil gallery. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 18, 2009 Author Share Posted December 18, 2009 Neither hole returns to the sump, one is the feed from the outlet side of the oil pump, the other feeds into the main oil gallery. i take it then the centre hole is the feed and the one going down, to the main oil gallery.or have i got that back to front. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 18, 2009 Share Posted December 18, 2009 Spin on filters always flow oil OUT through the centre hole into the main oil gallery, so the one on the perimeter of the hollow in the casting is the feed from the oil pump pressure side. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 18, 2009 Author Share Posted December 18, 2009 Spin on filters always flow oil OUT through the centre hole into the main oil gallery, so the one on the perimeter of the hollow in the casting is the feed from the oil pump pressure side. ideal thats one thing i wanted to find out,just waiting for the pics of the part you have (hopefully). Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 19, 2009 Author Share Posted December 19, 2009 started stripping the front off to fit the fmic.its started to snow lightly so descided to get a coffee.will be making the mounting brackets in a minute.has anybody left the pas cooling pipes in place. Quote Link to comment Share on other sites More sharing options...
Wez Posted December 19, 2009 Share Posted December 19, 2009 has anybody left the pas cooling pipes in place. You can only junk them if you fit another cooler. From memory some FMICs come with replacements where as others just require you to bend or move it. Some track setups replace them with a proper cooling matrix and 10mm piping, something that is on my todo list Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 20, 2009 Author Share Posted December 20, 2009 finished fitting the fmic today. Quote Link to comment Share on other sites More sharing options...
b_have Posted December 20, 2009 Share Posted December 20, 2009 Nice job! Now the tricky bit, fabricating the ic pipework.(I spent weeks making mine when I changed to the Jun style intake) Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 20, 2009 Author Share Posted December 20, 2009 Nice job! Now the tricky bit' date=' fabricating the ic pipework.(I spent weeks making mine when I changed to the Jun style intake)[/quote'] i know have to get some different bends and make a start i suppose.going to be doing it all out of stainless. Quote Link to comment Share on other sites More sharing options...
nevins Posted December 20, 2009 Share Posted December 20, 2009 Its nice to see a build like this actually getting finished, There's been a lot of members boasting this job and then it just never materializes, Well done. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 20, 2009 Author Share Posted December 20, 2009 Its nice to see a build like this actually getting finished, There's been a lot of members boasting this job and then it just never materializes, Well done. i am trying.mainly all fabrication work now thankfully as the wallet is empty. Quote Link to comment Share on other sites More sharing options...
nevins Posted December 20, 2009 Share Posted December 20, 2009 Just dont give up lol, I would love to see this up and running. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 20, 2009 Author Share Posted December 20, 2009 i certainly wont be giving up.planned to be ready for easter,but that was always going to be roughly.over running a bit at the moment mainly due to the weather,cold is ok rain puts a stop on play. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 20, 2009 Author Share Posted December 20, 2009 been thinking about the oil filter housing problem ,and looking at the relocation kit. drill a hole through the middle.then a hole in the side tapped out for a fitting.then screw into the block a hollow bolt .place the relocation part over this then secure with a nut.fit a 90 degree elbow to the hollow bolt.then the pipes can run from this to the part that holds the filter. Quote Link to comment Share on other sites More sharing options...
Dave Posted December 20, 2009 Share Posted December 20, 2009 your doing all this outside top respect, a great job and write up so far Quote Link to comment Share on other sites More sharing options...
