trinitom Posted May 17, 2010 Share Posted May 17, 2010 i havnt and that would be great if you could.its now becoming anoying that i cant seem to sort this stupid problem. ok, i will post a few. Link to comment Share on other sites More sharing options...
trinitom Posted May 17, 2010 Share Posted May 17, 2010 that may help you to find the problem:Ignition Systems - 2JZ-GE.pdf Link to comment Share on other sites More sharing options...
barneybrendan Posted May 17, 2010 Author Share Posted May 17, 2010 that may help you to find the problem: ideal cheers for that . Link to comment Share on other sites More sharing options...
DodgyRog Posted May 17, 2010 Share Posted May 17, 2010 I no this must be really annoying by now, didn't realise you didn't have a manual. I have CJ's manuals here, if you want to pop up and get them Link to comment Share on other sites More sharing options...
barneybrendan Posted May 17, 2010 Author Share Posted May 17, 2010 I no this must be really annoying by now, didn't realise you didn't have a manual. I have CJ's manuals here, if you want to pop up and get them trinitom going to try sending one to me. Link to comment Share on other sites More sharing options...
trinitom Posted May 17, 2010 Share Posted May 17, 2010 trinitom going to try sending one to me. it's still sending (67 mb) hope it doesn't fail. Link to comment Share on other sites More sharing options...
nevins Posted May 17, 2010 Share Posted May 17, 2010 Just a thought but have you tried swapping out the ignition module, had it with quite a few cars with the same symptoms. Link to comment Share on other sites More sharing options...
DodgyRog Posted May 17, 2010 Share Posted May 17, 2010 trinitom going to try sending one to me. Just give me a ring if you want it Link to comment Share on other sites More sharing options...
JODY T Posted May 17, 2010 Share Posted May 17, 2010 ive been thinking about this for the last hour, ive sent over a load of info about the ECU2, manuals, software, ideas etc.. It may help you out.. I hope it does.. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 18, 2010 Author Share Posted May 18, 2010 ive been thinking about this for the last hour, ive sent over a load of info about the ECU2, manuals, software, ideas etc.. It may help you out.. I hope it does.. chheers jody. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 20, 2010 Author Share Posted May 20, 2010 i removed the map ecu 2 today and hey presto the engine started first turn of the key.glad i know what the problem is,but still a bummer its the ecu. Link to comment Share on other sites More sharing options...
Smallshinyant Posted May 20, 2010 Share Posted May 20, 2010 yay.. congrats on getting it started. could of been worse, if it was not that you would be of really stuck. Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 20, 2010 Share Posted May 20, 2010 victory . yayyy. so tghe map 2 is for the bin then , what are your plans? Link to comment Share on other sites More sharing options...
JamieP Posted May 20, 2010 Share Posted May 20, 2010 AEM FIC seems good value. http://www.mkivsupra.net/vbb/showthread.php?t=207644 Link to comment Share on other sites More sharing options...
barneybrendan Posted May 20, 2010 Author Share Posted May 20, 2010 victory . yayyy. so tghe map 2 is for the bin then , what are your plans? not for the bin.map 2 have very good support team,so should be able to send it back for repair.they have a standard charge of $100 for repairing them.Going to try and get another one in the mean time so i can crack on.:):):) Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 20, 2010 Share Posted May 20, 2010 have you got good oil pressure on this motor? Link to comment Share on other sites More sharing options...
barneybrendan Posted May 20, 2010 Author Share Posted May 20, 2010 have you got good oil pressure on this motor? dont know yet i turned it off right away,will check tomorrow when i fit the standard 330 injectors back in. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 20, 2010 Author Share Posted May 20, 2010 AEM FIC seems good value. http://www.mkivsupra.net/vbb/showthread.php?t=207644 £800 mapped and fitted have to get more info on it to see if it will work with the charger. Link to comment Share on other sites More sharing options...
wile e coyote Posted May 20, 2010 Share Posted May 20, 2010 Swaped gauges tonight mate thats why not replyed back to text so your have a gauge tomorrow mate Link to comment Share on other sites More sharing options...
DodgyRog Posted May 20, 2010 Share Posted May 20, 2010 Thats good news mate, I am guessing there is a smile on your face again Link to comment Share on other sites More sharing options...
barneybrendan Posted May 20, 2010 Author Share Posted May 20, 2010 Swaped gauges tonight mate thats why not replyed back to text so your have a gauge tomorrow mate ideal cheers mate Link to comment Share on other sites More sharing options...
barneybrendan Posted May 20, 2010 Author Share Posted May 20, 2010 Thats good news mate, I am guessing there is a smile on your face again when it started yes ,but that soon went when i realized more expense on the ecu now. Link to comment Share on other sites More sharing options...
little num Posted May 20, 2010 Share Posted May 20, 2010 my engine was very good, never had a oil gauge fitted but was very clean inside and wet in both rockers, i did a trackday at oulton (full circuit) and did an impressive 2.08. Glad its beating again. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 20, 2010 Author Share Posted May 20, 2010 was surprised as i have number one plug out to test for a spark but it descided to start anyway,sounded like a tank with the plug out. Link to comment Share on other sites More sharing options...
tDR Posted May 20, 2010 Share Posted May 20, 2010 i removed the map ecu 2 today and hey presto the engine started first turn of the key.glad i know what the problem is,but still a bummer its the ecu. I did try to tell you! It will just need installed / setup by someone familiar with them. Link to comment Share on other sites More sharing options...
