barneybrendan Posted May 5, 2010 Author Share Posted May 5, 2010 Blimey, get some sleep fella. Dont want to make any silly mistakes. good luck as always. not much chance of that off to work in a bit till 6 tonighht then cracking on. Quote Link to comment Share on other sites More sharing options...
trinitom Posted May 5, 2010 Share Posted May 5, 2010 good luck with the new engine. Quote Link to comment Share on other sites More sharing options...
Pudsey Posted May 5, 2010 Share Posted May 5, 2010 Great dedication to the cause buddy............. Be seeing you at around 6pm then, if you need a hand that is? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted May 5, 2010 Share Posted May 5, 2010 not much chance of that off to work in a bit till 6 tonighht then cracking on. Is this the engine out of my GS300 that I gave to him? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 5, 2010 Author Share Posted May 5, 2010 (edited) Is this the engine out of my GS300 that I gave to him? i dont no.are you saying that the engine i just bought for £200 was given away to start with.i hope not. Edited May 5, 2010 by barneybrendan (see edit history) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted May 5, 2010 Share Posted May 5, 2010 i dont no.are you saying that the engine i just bought for £200 was given away to start with.i hope not. No, I gave him a GS300 quite some time ago, but it could be just a coincidence. The GS300s 2JZ is slightly different to the Supras (IE i'm sure the sump is different) He had an NA Supra so it's quite possible it's from that. Besides which, I donated it to him for parts or to use as I felt sorry for him after the trouble he had with his last Supra, so I have no problem with him selling bits on. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 5, 2010 Share Posted May 5, 2010 Good luck mate you deserve it, with your dedication and stamina you go far wrong:thumbs: Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 5, 2010 Author Share Posted May 5, 2010 (edited) well engines are now swaped over going to be an expert at this rate.cheers to pudsey again for the hand.jsut need to bolt everything back on now so should crack that over the next couple of nights.then the weekend fingers crossed will be test time again. Edited May 5, 2010 by barneybrendan (see edit history) Quote Link to comment Share on other sites More sharing options...
jagman Posted May 5, 2010 Share Posted May 5, 2010 Given the Unknown nature of the new engine ,and your previous engine ,it may be worth flushing the oil system out knock up a mix of Derv/ATF/cheap oil , slightly overfill and run just above idle for 5-10 mins Dump the mix and replace the filter - check out the crap that comes out!!! Do a compression check on the engine after this - at least you then have a clean engine with known compression for reference You dont hang around do you? - thats commitment Quote Link to comment Share on other sites More sharing options...
ScottC Posted May 5, 2010 Share Posted May 5, 2010 Don't tell me you did that in under 3 hours!! Quote Link to comment Share on other sites More sharing options...
little num Posted May 5, 2010 Share Posted May 5, 2010 hey folks just put some minds at rest, this engine is 100% and was removed from my own mkiv supra as i have recently fitted a 1JZ, if you look in multimedia you will find me video of the 1JZ running. Barny you will not have any problems with this engine so dont do a engine flush as its not needed. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 5, 2010 Author Share Posted May 5, 2010 cheers i have to crack on while the weather is good as you can see all work is done on the drive.cheers james i was confident anyway as its only been out a short time and watched your vid.not sure how long it took . Quote Link to comment Share on other sites More sharing options...
Blackie Posted May 5, 2010 Share Posted May 5, 2010 well engines are now swaped over going to be an expert at this rate.cheers to pudsey again for the hand.jsut need to bolt everything back on now so should crack that over the next couple of nights.then the weekend fingers crossed will be test time again. F**k me Barny you dont mess about do you, Now if you could just work out how to wire up a TT for me Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 5, 2010 Author Share Posted May 5, 2010 F**k me Barny you dont mess about do you, Now if you could just work out how to wire up a TT for me electrics mate im buggard . Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 5, 2010 Share Posted May 5, 2010 Given the Unknown nature of the new engine ,and your previous engine ,it may be worth flushing the oil system out knock up a mix of Derv/ATF/cheap oil , slightly overfill and run just above idle for 5-10 mins Dump the mix and replace the filter - check out the crap that comes out!!! Do a compression check on the engine after this - at least you then have a clean engine with known compression for reference You dont hang around do you? - thats commitment Really? does this not strip the bearings? The last time I flushed an a-series engine a few years back it knocked like a biiiaaaatch due to the amount of crud it removed which had filled in the bearings over the 30odd years of it's life That said if this works I'll add it to my list of interesting tips Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 5, 2010 Author Share Posted May 5, 2010 holy overcooked german sausage batman, you deseve this to be a massive sucsess . hats off to you, i would have thrown my tools and set fire to it by now ive just noticed ive cracked the headers now so have to take the wrapp off and weld it up.the facelift engine mounts are causing a clearance issue bummer as i gave you the old mounts didnt i.if your not using them any chance of swapping them for the ones i have.i think i trimmed one side to clear the header. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 5, 2010 Share Posted May 5, 2010 yea no worries mate , im pretty sure you gave me 2 passinger side mounts though. ill have a look in the workshop in the morning Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 5, 2010 Author Share Posted May 5, 2010 yea no worries mate , im pretty sure you gave me 2 passinger side mounts though. ill have a look in the workshop in the morning i have to look at home in the shed aswell then as ive had a fiew engines here now. Quote Link to comment Share on other sites More sharing options...
jagman Posted May 6, 2010 Share Posted May 6, 2010 Really? does this not strip the bearings? The last time I flushed an a-series engine a few years back it knocked like a biiiaaaatch due to the amount of crud it removed which had filled in the bearings over the 30odd years of it's life That said if this works I'll add it to my list of interesting tips It works unbelieveably well , the crap that comes out of what you thought was a clean engine is an eye opener - atf has a high detergent level -as any small crud in a gear box can cause big problems due to small passageways and ball valves ,so it breaks this down . on turbo cars you dont want any high revs to spool the turbo ,just idle or fast idle -cars with hydraulic lifters it keeps them gum free and stops them ticking , you can also just add atf just prior to changing the oil at a normal interval too. Somehow the engine seems to run run smoother post flushing ,but it could be all in the mind Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted May 6, 2010 Share Posted May 6, 2010 It works unbelieveably well , the crap that comes out of what you thought was a clean engine is an eye opener - atf has a high detergent level -as any small crud in a gear box can cause big problems due to small passageways and ball valves ,so it breaks this down . on turbo cars you dont want any high revs to spool the turbo ,just idle or fast idle -cars with hydraulic lifters it keeps them gum free and stops them ticking , you can also just add atf just prior to changing the oil at a normal interval too. Somehow the engine seems to run run smoother post flushing ,but it could be all in the mind At what percentage mix would you use with say 5ltr oil ? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 7, 2010 Author Share Posted May 7, 2010 before i refit eveything another issue i had was that injectors keep blowing the o rings apart and leaking.any ideas on the reason why tis could be happening Quote Link to comment Share on other sites More sharing options...
little num Posted May 8, 2010 Share Posted May 8, 2010 dont forget there is no oil in the new engine, i used silko pro s 10-50. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2010 Author Share Posted May 8, 2010 dont forget there is no oil in the new engine, i used silko pro s 10-50. thats the first thing i got fresh oil. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 9, 2010 Author Share Posted May 9, 2010 reconnected everything this morning.made sure the oil pipes were flowing by cranking the engine over,then it was time to fire it up.As the engine had only been out a couple of weeks i thought it would fire up after a couple cranks,but no i have just flattend a fully charged battery trying to get it to fire.Needless to say im a little peeved at the moment.Battery is now back on charge and will try again tomorrow,having the rest of the day away from it might be a good idea. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 9, 2010 Share Posted May 9, 2010 reconnected everything this morning.made sure the oil pipes were flowing by cranking the engine over,then it was time to fire it up.As the engine had only been out a couple of weeks i thought it would fire up after a couple cranks,but no i have just flattend a fully charged battery trying to get it to fire.Needless to say im a little peeved at the moment.Battery is now back on charge and will try again tomorrow,having the rest of the day away from it might be a good idea. Have you done the usual spark/fuel check? Next step, check the sensors are plugged all plugged in. Quote Link to comment Share on other sites More sharing options...
