David P Posted May 8, 2011 Share Posted May 8, 2011 (edited) The Beastie is biting at your last straw. Edited May 8, 2011 by David P (see edit history) Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2011 Author Share Posted May 8, 2011 David2009 said: The Beastie is biting at your last straw. It certianly is ,had just about enough now .more down to buying crap and the major lack of parts in this country.I dont want to chuck the towel in just yet though as the couple sneaky drives i had when i got back from afr were great. Link to comment Share on other sites More sharing options...
Guigsy Posted May 8, 2011 Share Posted May 8, 2011 a charged soarer lump would be nice Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2011 Author Share Posted May 8, 2011 Not sure what im going to do at the moment looking at the vortech ones at the moment. Link to comment Share on other sites More sharing options...
Pudsey Posted May 8, 2011 Share Posted May 8, 2011 (edited) That's a bloody nightmare buddy. Sorry to hear that it didn't quiet down once you turned it over, lets hope the seller has a bit of a conscience hey. Drop them a line and see what they come back with. I hear the sound of a V8 Twin Supercharger on the horizon......... Edited May 8, 2011 by Pudsey spelling (see edit history) Link to comment Share on other sites More sharing options...
Scott Posted May 8, 2011 Share Posted May 8, 2011 I would definitely get onto the seller. Ebay don't even let you file a claim till after 3 weeks so I wouldn't worry about the time that has elapsed. I'm pretty sure you will have comeback Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2011 Author Share Posted May 8, 2011 just sent them a message so will wait then open a dispute tomorrow.The thing is i dont like things to beat me but thats ok with an endless wallet full of cash. Link to comment Share on other sites More sharing options...
hemmjonny Posted May 8, 2011 Share Posted May 8, 2011 bad luck mate, hope you get it fixed. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2011 Author Share Posted May 8, 2011 ive just sent magnusun products an email about rebuilding the unit .I couldnt with my original as the casing was trashed aswell.As with most places they may need a core exchange if they have them already done.going to see if my engineers can make me a hub to change pulleys easily. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2011 Author Share Posted May 8, 2011 the guy from ebay has said to send it back for testing Link to comment Share on other sites More sharing options...
garethr Posted May 8, 2011 Share Posted May 8, 2011 I don't think it's hard to rebuild an Eaton if the rotors and housing are OK. It's a pretty simple device. http://www.soarerworld.com/forum/showthread.php?t=6269 Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2011 Author Share Posted May 8, 2011 garethr said: I don't think it's hard to rebuild an Eaton if the rotors and housing are OK. It's a pretty simple device. http://www.soarerworld.com/forum/showthread.php?t=6269 its getting hold of all the bearings.most places you can get the snout repair kit .its only if the housing is duff that your knackerd.Have found rotor packs aswell but they are pricey. Well that the charger back off now . Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2011 Author Share Posted May 8, 2011 Im going to take my knackerd charger to my local bearing place to see if they can match them all up.Ive checked the charger over again and the rotors seem spotless no strike marks or signs of wear.The pulley has a bit more play in it now,may be just because the bigger pulley makes it more noticeable.Im going to strip it down myself instead of sending it back as it was hard enough finding a replacement one in the first place.Im also thinking about mounting a throttle body before the charger to try and cut down on some of the noise. Link to comment Share on other sites More sharing options...
wile e coyote Posted May 8, 2011 Share Posted May 8, 2011 just seen this mate gutted for you Link to comment Share on other sites More sharing options...
Guest ugp Posted May 8, 2011 Share Posted May 8, 2011 Keep going at it mate, you'll get there in the end. What you've done so far is great, don't give in to the 'ing thing! Link to comment Share on other sites More sharing options...
barneybrendan Posted May 8, 2011 Author Share Posted May 8, 2011 I will see what tomorrow brings Link to comment Share on other sites More sharing options...
barneybrendan Posted May 9, 2011 Author Share Posted May 9, 2011 Ive pulled the charger apart and the standard nylon spring loaded coupler has a lot of ware .replaced it with the new nylon one i had and it seems nice and tight.The rear bearings seem fine but could do with a bit of grease.The grease is blue,anybody know what the blue grease is.Need to get some of the charger oil now which aint cheap.Didnt get time to go to the bearing shop yet .Im going to strip the spare snout down tomorrow to get the bearing out . Link to comment Share on other sites More sharing options...
Guest ugp Posted May 9, 2011 Share Posted May 9, 2011 Didn't think you'd give up Link to comment Share on other sites More sharing options...
barneybrendan Posted May 9, 2011 Author Share Posted May 9, 2011 ugp said: Didn't think you'd give up Was just ranting i think as i was right efed off at the time. Link to comment Share on other sites More sharing options...
Pudsey Posted May 9, 2011 Share Posted May 9, 2011 Great news the inside of the replacement is okay. Hopefully, it will be as good as new once its back together, loads of trouble free miles then. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 9, 2011 Author Share Posted May 9, 2011 Pudsey said: Great news the inside of the replacement is okay. Hopefully, it will be as good as new once its back together, loads of trouble free miles then. that would be nice but i very much dout it. Link to comment Share on other sites More sharing options...
David P Posted May 9, 2011 Share Posted May 9, 2011 It doesn't look terminally ill, I'm sure you can nurse it back to full health. I don't know about the blue grease, maybe you have to squeeze a couple of these. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 9, 2011 Author Share Posted May 9, 2011 David2009 said: It doesn't look terminally ill, I'm sure you can nurse it back to full health. I don't know about the blue grease, maybe you have to squeeze a couple of these. the grease is kendall super blue ,trying to find some in this country now . Link to comment Share on other sites More sharing options...
David P Posted May 9, 2011 Share Posted May 9, 2011 It might be worth checking out the spec and cross referencing it to other brands? Link to comment Share on other sites More sharing options...
barneybrendan Posted May 9, 2011 Author Share Posted May 9, 2011 my brain would explode trying to match all the details up. this is the blue stuffs specs http://www.conocophillipslubricants.com/documents/kendall/greases/Ken%20L-427%20Super%20Blu%20Grease%20TDS%20Web.pdf Link to comment Share on other sites More sharing options...
