David P Posted June 22, 2010 Share Posted June 22, 2010 barneybrendan said: Also on the bulk head side of the y piece intake theres a larger vacum pipe,what would this of connected to. It connects to the breather on the rocker cover, right next to it. Link to comment Share on other sites More sharing options...
barneybrendan Posted June 22, 2010 Author Share Posted June 22, 2010 David2009 said: It connects to the breather on the rocker cover, right next to it. ideal so i can now blank it off. Link to comment Share on other sites More sharing options...
David P Posted June 22, 2010 Share Posted June 22, 2010 (edited) Edit. Edited June 22, 2010 by David P (see edit history) Link to comment Share on other sites More sharing options...
Fearless Posted June 22, 2010 Share Posted June 22, 2010 barneybrendan said: just realized i didnt order the 2 32mm ones for the bov.just rang the ebay company and he said he will make them now and look out for my payment so he can send them in tonights post.top guys. Is that http://stores.ebay.co.uk/DPH-Silicone-Hose ? that's where I got mine too, very helpful people and top class products Can't wait to see what this can do once you've got it mapped. Link to comment Share on other sites More sharing options...
barneybrendan Posted June 22, 2010 Author Share Posted June 22, 2010 Fearless said: Is that http://stores.ebay.co.uk/DPH-Silicone-Hose ? that's where I got mine too, very helpful people and top class products Can't wait to see what this can do once you've got it mapped. yep thats them as you say very helpfull. Link to comment Share on other sites More sharing options...
jagman Posted June 22, 2010 Share Posted June 22, 2010 Fair play, given the problems you have had along your conversion path,you have stuck to your task , many would have given up by now. It gives everyone an insight into just how hard such projects are, and you have done it all by eye , no CAD/CAM,and trial and error used .and all for less than a F1 team spend on one steering link ! Such DIY rocks, who needs HKS Link to comment Share on other sites More sharing options...
barneybrendan Posted June 22, 2010 Author Share Posted June 22, 2010 jagman said: Fair play, given the problems you have had along your conversion path,you have stuck to your task , many would have given up by now. It gives everyone an insight into just how hard such projects are, and you have done it all by eye , no CAD/CAM,and trial and error used .and all for less than a F1 team spend on one steering link ! Such DIY rocks, who needs HKS cheers have to say the help ive had off different people manualy and good advice and knowledge has been great.wouldnt of got this far else. Link to comment Share on other sites More sharing options...
David P Posted June 22, 2010 Share Posted June 22, 2010 (edited) I can't see how you have plumbed in the engine breather pipework, but if you haven't already, you need to have those rocker breather pipes connected to the suck side of the induction system to prevent over pressure in crank case. Otherwise you could be blowing out a crank oil seal. Edited June 22, 2010 by David P (see edit history) Link to comment Share on other sites More sharing options...
barneybrendan Posted June 22, 2010 Author Share Posted June 22, 2010 David2009 said: I can't see how you have plumbed in the engine breather pipework, but if you haven't already, you need to have those rocker breather pipes connected to the suck side of the induction system to prevent over pressure in crank case. Otherwise you could be blowing out a crank oil seal. i have them going straight into the catch can then vented out under the car. Link to comment Share on other sites More sharing options...
barneybrendan Posted June 22, 2010 Author Share Posted June 22, 2010 fiew more things done today. wired the fans in with darren,but the temp controler isnt right the markings dont line up so temp will have to be done by trial and error.The wirring still has to be tidied up ,could do with some sort of box to fit it all in. the intercooler pipes are now fitted back on with silicone couplings but the couplings were bigger than the crap rubber ones so all the pipes had to be trimmed again to fit.The bov needs adjusting still as its still open when throttle pressed. The oil filter has been moved back and now clears the bumper mesh. Had a bit of a headache as the car wouldnt start again.Found out it was the spark plugs breaking down and sparking nilly willy.These came out of pudseys vvti and were iridium.Orderd some ngk 8's now. The car sound much better with the sweeping 180 degree bends now,none of that air turbulance noise.All you get now is the whistle from the charger,oh and the exhaust note which is rather loud this needs changing soon. Bumper is now bolted back on properly and it finally looks like my old car again. At the moment it is smoking rather badly very rich,plus the mix match of plugs in there at the moment aint helping. first time for 9 months that the car has move dmore than a foot.You can definately feel the car wants to go as you rev a little and pull away,and thats with the bov still venting off slightly. :d: Link to comment Share on other sites More sharing options...
Smallshinyant Posted June 22, 2010 Share Posted June 22, 2010 Looks so much better all in one piece. Sorry i might of missed it, but when does it get handed to AFR? Link to comment Share on other sites More sharing options...
barneybrendan Posted June 22, 2010 Author Share Posted June 22, 2010 Smallshinyant said: Looks so much better all in one piece. Sorry i might of missed it, but when does it get handed to AFR? i rang them today to see if it was ok to drop it up to them next week.about a 500 mile round trip.then have to do it again to pick it up. might even wash it as it hasnt seen any soap in 9 months Link to comment Share on other sites More sharing options...
wile e coyote Posted June 23, 2010 Share Posted June 23, 2010 nice one mate dont forget to mention about my boost controler to afr Link to comment Share on other sites More sharing options...
Smallshinyant Posted June 23, 2010 Share Posted June 23, 2010 you sticking it on a trailer for the trip? Link to comment Share on other sites More sharing options...
barneybrendan Posted June 23, 2010 Author Share Posted June 23, 2010 Smallshinyant said: you sticking it on a trailer for the trip? yep. got some ngk bpr8es plugs,but they dont fit so its stripped down at the moment until i get some plugs. Link to comment Share on other sites More sharing options...
DodgyRog Posted June 24, 2010 Share Posted June 24, 2010 When are you planning the trip up to AFR Brendan Link to comment Share on other sites More sharing options...
barneybrendan Posted June 24, 2010 Author Share Posted June 24, 2010 DodgyRog said: When are you planning the trip up to AFR Brendan one day next week if i canget hold of some damn plugs. Link to comment Share on other sites More sharing options...
wile e coyote Posted June 24, 2010 Share Posted June 24, 2010 did you manage to get hold of dude about the plugs ? Link to comment Share on other sites More sharing options...
nevins Posted June 24, 2010 Share Posted June 24, 2010 Nice to see this coming along so fast mate, will have to see this at some point. Link to comment Share on other sites More sharing options...
barneybrendan Posted June 24, 2010 Author Share Posted June 24, 2010 (edited) wile e coyote said: did you manage to get hold of dude about the plugs ? no mate ive put the na ones back in they were the same just 7's instead of 8's. didnt feel like doing much to it myself so had some help.funny when your help falls asleep on the engine.Bless her she learning and putting up with me and the car. car sounds a lot better apaert from the bov venting off still.check out the latest video Edited June 24, 2010 by barneybrendan (see edit history) Link to comment Share on other sites More sharing options...
wile e coyote Posted June 25, 2010 Share Posted June 25, 2010 Ha Ha bless Link to comment Share on other sites More sharing options...
Supra Gaz Posted June 25, 2010 Share Posted June 25, 2010 Fantastic project, what a brilliant car Link to comment Share on other sites More sharing options...
The Raven Posted June 25, 2010 Share Posted June 25, 2010 oooo i cant wait to see what happens next Link to comment Share on other sites More sharing options...
barneybrendan Posted June 27, 2010 Author Share Posted June 27, 2010 had the car ticking over for a while to see what oil pressure drops to.On idle it drops to 20 on the gauge ,also found that the temp gauge isnt working as that is still flashing away on the same number as when the car is started. So thats the oil temp and boost gauge not working correctly and the temp set switch for the fans. Every time i think im ready to take the car to AFR something keeps cropping up.My plan now is to take the car up as the gauges can be sorted after when the car is running right,so its trailer up and back i think. Link to comment Share on other sites More sharing options...
barneybrendan Posted June 28, 2010 Author Share Posted June 28, 2010 just booked the trailer hire for next week now as it is booked out this week.planning on the trip early wednesday morning.Just hope they have ear defenders at AFR. Link to comment Share on other sites More sharing options...
