Chris Wilson Posted November 23, 2009 Share Posted November 23, 2009 You should be able to buy a used two post ramp for under 500 quid, a bit more if it's single phase. A 2 post ramp is a lot more practical for actually working on the car than a 4 post ramp. Link to comment Share on other sites More sharing options...
Konrad Posted November 23, 2009 Share Posted November 23, 2009 I also do advice 2 post ramp Andrew, better access to everything Link to comment Share on other sites More sharing options...
Wez Posted November 23, 2009 Share Posted November 23, 2009 Just had a measure in the garage and I am going to a bit pushed to fit even a two poster Width at widest point : 3140mm Height at widest point : 2130mm Overall Height : 2280 Normal width : 2790 There is enough space above and around the car but I dont think they do any ramps that compact, unless there are some single post units available. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 23, 2009 Share Posted November 23, 2009 This is the exact same ramp I use here at home: http://cgi.ebay.co.uk/TECALEMIT-2-POST-CAR-LIFT-HOIST-RAMP_W0QQitemZ150391336375QQcmdZViewItemQQptZUK_Lifting_Moving_Equipment?hash=item230405adb7 It WILL run off a phase convertor, as he says, but you really need a 10 HP one, and they demand a 30 amp supply. I have a 100 amp single phase feed as I use a fairly hefty single phase TIG. All this stuff adds up.... I have the spec sheet for this ramp somewhere with all dimensions. It'll lift a Rolls Royce OK. Link to comment Share on other sites More sharing options...
mobsta_01 Posted November 23, 2009 Share Posted November 23, 2009 Can you fellas help me on this one please? I have seen this 4-Post Ramp for sale (sub-2k incl VAT) and I think it would be a very useful bit of kit. I intend to put it in my garage but isn’t there some rule on the thickness of the concrete base required to mount such a lift etc? the add says they can deliver and install it for you, so i think it'd be best if you tell them what sort of garage you have before you decide to buy Link to comment Share on other sites More sharing options...
Wez Posted November 23, 2009 Share Posted November 23, 2009 I found a compact two poster that would fit in my garage http://www.dannmar.com/dannmar-products/two-post-lifts/maxjax.html Bit pricey though Link to comment Share on other sites More sharing options...
SupraAyf Posted November 24, 2009 Author Share Posted November 24, 2009 the add says they can deliver and install it for you, so i think it'd be best if you tell them what sort of garage you have before you decide to buy Do you mean size of garage etc? If so then even the bigger lifts will easily fit in mine. If there is something else that I need to ask then please clarify - cheers;) Link to comment Share on other sites More sharing options...
Rob Posted November 24, 2009 Share Posted November 24, 2009 You should definitely get one. You're quite local I believe. I've always liked you, I think you're one of the best members on here, no really. Say, have you been working out? Link to comment Share on other sites More sharing options...
SupraAyf Posted November 25, 2009 Author Share Posted November 25, 2009 You should definitely get one. You're quite local I believe. I've always liked you, I think you're one of the best members on here, no really. Say, have you been working out? Come around and use it when I'm about then Rob. For your diary, that will be: 18 Feb 27 May 07 Aug 31 Oct and the 08 Jan 2011 Not sure what's happening thereafter:d Link to comment Share on other sites More sharing options...
pete_TT Posted November 25, 2009 Share Posted November 25, 2009 Im thinking about getting a 2 poster for my workshop. Any recomendations for makes to look out for at a sensible price? (I have 3 phase) Link to comment Share on other sites More sharing options...
SupraAyf Posted November 25, 2009 Author Share Posted November 25, 2009 Just a quick question since Pete has mentioned 2-post ramps but can the driver get in and out of a Supra easily with a 2-poster. There's no problem with a 4-poster, clearly, but the posts are where the doors are on a 2-post set-up? Link to comment Share on other sites More sharing options...
edge Posted November 25, 2009 Share Posted November 25, 2009 Dont bother wasting money on cheap branded stuff, and i have also heard that sealy? are using cheap imported units too. Go for something like a Stenhoj as the cheap ramps do fail. My friend in devon has heard of 3 ramps going wrong with people underneath in the last 6 months and ive seen it happen in front of me too. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted November 25, 2009 Share Posted November 25, 2009 I would go with a 2 post lift so much easier to work around. Have a look at the dannmar portable range http://www.dannmar.com Link to comment Share on other sites More sharing options...
MONKEYmark Posted November 25, 2009 Share Posted November 25, 2009 guy next door in my new house has a 4 post lifter in a brick built garage as he a mechanic working from home.said his garage cost £22000 to build and had to get building regulations on each step of the build.he has all the snap on equipment and a toolbox that fills the whole back wall.he was telling me he has a diagnostic snap on computer that was £6k. he has a snap on van come once a week.great set up he has.would love a set up like that with worksop to potter on car.will have to be happy to have a old up and over garage for now lol Link to comment Share on other sites More sharing options...
