hodge Posted November 23, 2009 Share Posted November 23, 2009 I will be running a -8an fuel line to a filter then split to 2x-6ans with 1 each side of the rail. Do I need to upgrade the return line to maybe a -6an or will the stock return be upto the job. Thanks John Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 23, 2009 Share Posted November 23, 2009 Depends on how much excess return flow the pump you use gives. You'll soon find out if it's too small as fuel pressure without the engine running won't respond to FPR adjustment. If it responds down to a bit below the base pressure you need to run it's big enough. Quote Link to comment Share on other sites More sharing options...
hodge Posted November 23, 2009 Author Share Posted November 23, 2009 Well I dont want to get everything fitted and running and realise I have to replace the return line so I recon ill just change it anyway. Thanks Chris. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 23, 2009 Share Posted November 23, 2009 I have made a small batch of alloy tank top plates for Skyline R33 and R34's to allow proper unions down to in tank pumps and proper high amperage electrical connectors. I don't have a Supra tank top plate (moulded plastic) to measure, they *MAY* be the same, is there any interest in these? I have sold a few to the Skyline community. £60 quid each without fittings. Quote Link to comment Share on other sites More sharing options...
dude Posted November 23, 2009 Share Posted November 23, 2009 I have made a small batch of alloy tank top plates for Skyline R33 and R34's to allow proper unions down to in tank pumps and proper high amperage electrical connectors. I don't have a Supra tank top plate (moulded plastic) to measure, they *MAY* be the same, is there any interest in these? I have sold a few to the Skyline community. £60 quid each without fittings. They look nice Chris, if you measure them I can check for you and see how different they are or are not. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 23, 2009 Share Posted November 23, 2009 An absolutely appalling drawing below: Quote Link to comment Share on other sites More sharing options...
