MY MKII Resto Mods 7MGTE/2JZGTE 15 years and counting
Guest Daves2JZGTE
Guest Daves2JZGTE
Rather then dink with other throttle cables I just ordered a stock MK4 TT cable and wouldn't you know it.............................................................PERFECT!!!
Now for a contrivance move on my part!!!!
With my custom made by me seat brackets the seat is just about the same height as the stock seat maybe + .25 inch higher if that. AND I like it.
Before
after
That right there was worth all the effort let alown the power gain..... thinking of getting plaits for the car
eather
SLOW
or
AllShow
LOL
  • Replies 55
Guest Daves2JZGTE
New toy on its way for my swap a
Innovative OT-1
http://www.innovatemotorsports.com/products/ot1.php
This with my LC-1 and i will have data logging on line..... WOOT
O gota 6SPD ecu coming in too rather then mes with the auto code problems
O and i should have the fuel safety setup with in the week
This looks bad but its not.....LOL still have to loom the sub harness now that i know its works right.
07-01-2009 2J started for the first time!!! ER um 01-07-09 I think thats how you do it... LOL "Stupid American" September 1st of 09
O forgot to show the glove box after the wiring was all done
All systems working as stock with no check light coming on!!!!!!!!!!
Dynos are in
18psi and 24psi stock ecu
OK this brings us up the August of 2009 and im not done yet.
We still have to trade in the twins for a single!!!
Edited by Daves2JZGTE (see edit history)
Guest Daves2JZGTE
Any plans to change from the burgundy interior (which looks way too dated IMHO)?
yea the inside is on the list of things still to do but its really really low in the list....
This is a brilliant thread and a great car!! Looking forward to the rest of the bits you have yet to post ;)
Have you bean cheating? Did you skip to the end of the book? :eyebrows:
Cuz i have no idea what you mite be talking about!!!!!:D
ok i lied:p
Guest Daves2JZGTE
So here we are starting over!!!
They where fun but moving on (The twins are sold. Not in there new home but spoken for) to something that fits my driving stile better.
Still sooper cool
So what are we guna do now???
New air COOLED 6262DBB with a .68 AR
and im going with a cast manifold
This build is all about spool and broad power ban
you see with the twins i had a blast cruising on the freeway and running in a strait line but when i run the canyons i was falling right into transition so the power delivery was not what im use to. Having a 5speed and not a 6 didnt help with this as each shift was a bigger drop in the rpm range. So the new setup should have power when i wont it. BUT i will loose the fun 1st turbo passing on the freeway power.
for 10 years i had a 7MGTE with a modded ct26 to4e 60 trim and this is what my power looked like.
So i got use to having power from under 4000 to 5500 when id shift.
then i moved on to this.
as you can see the power moved. I still have about the same usebole power range but its in a different spot. So i kept finding myself dropping into the dead spot with the twins. Having an ideal driving preference in my supra i decided i dont wont to adapt to the new power range i wont the motor to adapt to me.....
So the new setup should be a hybred of the 2 dynos I.E 400+ TQ from by or below 4000 to 6500 shift. We will see if this works as i think it will!!
Im only shooting for ~400 to 450 on the street with pump gas should be like 12 to 16psi to hit that HP/TQ range. witch is 99% of my driving. I dont like to run more then ~17 psi on 91 pump crap
so this is my build guide
PHR stage one setup
or this home made one
With this setup i can still use the stock cats and or open DP witch i have in the car now.
I got some materials together then dusted of my cutting and welding equipment and got to work
Got the big part tacked up
after that i had to get the WG all lined up to have the dump pipe to go back in followed by a place to add the o2 bung. And this is what i came up with
Man that wasnt ez. I really wont to make another set as this one really seams like a mockup pice but it will do.
Paint time.
So now thats all done....... have to get some more parts for the next steps!!!
Guest Daves2JZGTE
more pics
now to move on to the oil feed and drain............
Getting closer
now that i made it this far i noticed i made a big mistake
ok lets try this again!!
NOW
before
WG now going in @ a 45 degree angle with the flow not against :32:
before
After
  • 2 weeks later...
  • 2 weeks later...
Guest Daves2JZGTE
Got my new GoPro vid camera so i made a vid.... camera location wasnt the best but o well was my first time using the camera.
  • 9 months later...
Guest Daves2JZGTE
Little update
Added HKS 264 cams
Dynoed @ 18 psi and 17psi
O and i got tired of the aftermarket wheel look so i went back to stock
