Wet passenger seatbelt
ManwithSupra
I seem to have a wet passenger seatbelt but nothing else is wet (such as the floor, carpet and the seat etc) the weather has been pretty bad but water should not be coming into the car. I have read a few of the posts on here about similar problems, but there have been no updates on fixes.
I have checked the seals and they seem to be ok, no cracks or wear which is making me think it must be the little side Qtr window, if it is that does it mean the stuff they use to bond the window to the car has failed?
The thing is it is pouring with rain right now and i am not sure how long the car has been in this state, so now i am worried about the dreaded rust setting in....
Would it be better to take my car to a bodyshop and see if they can take the window out and rebond it?
I had the same on my NA. it ill be the rear qtr windows at the front that are leaking down onto the seat belt where it mounts in the rear quater panel. I fixed mine by undoing the window bolts, sqirting some silicon seal between the windows and the frame and then tighten it all up. Be really careful though as the studs are old, quite small and could easily snap off.
