jevansio Posted November 22, 2009 Share Posted November 22, 2009 Is there such a thing as a short drill bit? 12mm ones are huge, and I've got a bit of a space problem, a drill half the size (stubby) would be perfect, I've been looking & can't find anything. Link to comment Share on other sites More sharing options...
absz Posted November 22, 2009 Share Posted November 22, 2009 cut it in half using a angle grinder:innocent: Link to comment Share on other sites More sharing options...
bromy Posted November 22, 2009 Share Posted November 22, 2009 How much protrusion from the end of your chuck can you get away with? Link to comment Share on other sites More sharing options...
jevansio Posted November 22, 2009 Author Share Posted November 22, 2009 How much protrusion from the end of your chuck can you get away with? 9cm, 10cm deg wouldn't fit Link to comment Share on other sites More sharing options...
jevansio Posted November 22, 2009 Author Share Posted November 22, 2009 I came across these stub drills, would they be any good http://www.tapdie.com/html/stub_drills_screw_machine_dril.html Link to comment Share on other sites More sharing options...
Kev.O Posted November 22, 2009 Share Posted November 22, 2009 Jay, have you thought about using an angled drill? Link to comment Share on other sites More sharing options...
johnd-mkiv Posted November 22, 2009 Share Posted November 22, 2009 Id just cut the drill bit down and regrind it Link to comment Share on other sites More sharing options...
AndyT Posted November 22, 2009 Share Posted November 22, 2009 Regrinding is a specialist operation. I know it can be done, but if it's done wrong you'll just get a lump of metal that heats up rather than cuts. Link to comment Share on other sites More sharing options...
Kev.O Posted November 22, 2009 Share Posted November 22, 2009 What about something like this? Link to comment Share on other sites More sharing options...
jevansio Posted November 23, 2009 Author Share Posted November 23, 2009 Yeah was looking into something like that Kev. My mate has said he has a very short drill he uses for work & is going to borrow me it so should be sorted Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 23, 2009 Share Posted November 23, 2009 LEND me it..... Sorry, pet hate You could buy a standard 12 mm drill, cut it short with angle grinder, then get someone to weld on a short stepped sleeve, making sure it's true in a lathe. Depends on how deep the drill has to go. Link to comment Share on other sites More sharing options...
bluecoup Posted November 23, 2009 Share Posted November 23, 2009 if your not drilling something hardcore id just chop the drill bit in half and use the already sharp end no need to sharpeb it then Link to comment Share on other sites More sharing options...
Scott Posted November 23, 2009 Share Posted November 23, 2009 If you send me it I'll cut and re-grind it for you. We are in the middle of a move at the moment so I would just need to check the buff is still kicking about. Link to comment Share on other sites More sharing options...
jevansio Posted November 23, 2009 Author Share Posted November 23, 2009 LEND me it..... Sorry, pet hate You could buy a standard 12 mm drill, cut it short with angle grinder, then get someone to weld on a short stepped sleeve, making sure it's true in a lathe. Depends on how deep the drill has to go. , all my work mates pick me up on that all the time, I can NEVER got borrow & lend the right way round Link to comment Share on other sites More sharing options...
Shadow Beast Posted November 23, 2009 Share Posted November 23, 2009 just cut the end off that goes into the drill, no need to mess around with re sharpening the other end, de burr it with a file and jobs a good un. Richie Link to comment Share on other sites More sharing options...
Kev.O Posted November 23, 2009 Share Posted November 23, 2009 , all my work mates pick me up on that all the time, I can NEVER got borrow & lend the right way round Just for you Jay Link to comment Share on other sites More sharing options...
jevansio Posted December 5, 2009 Author Share Posted December 5, 2009 I fixed the manifold studs today, this was the drill I used to get in Link to comment Share on other sites More sharing options...
dangerous brain Posted December 5, 2009 Share Posted December 5, 2009 For future reference HSS drill bits are very brittle. Stick a towel over it then stick it in a vice and smack it short and hard tap with a hammer and it will snap straight off leaving you with a shorter drill bit. 12mm will need a damn good tap though. Link to comment Share on other sites More sharing options...
nevins Posted December 5, 2009 Share Posted December 5, 2009 If you know a mechanic or coach builder they will have just the tool, a right angled drill but more than likely it will be an air tool. Link to comment Share on other sites More sharing options...
