Brian Crower Cams
add heywood
Having a llok around for cams, and found some Brian Crower Stage 3 272's. Doing a bit of research and it says on their website I need titainium retainers and springs to use. I thought these were only needed if running high than stock rpm's. Any advice? I can probably get HKS 272's for a little bit more money if need be.
I would go for some 264's anyway mate :)
I Still reckon Ad just to get a smaller Borg warner turbo like the s300 91/79 and not bother with cams. The turbos are not expensive and alot easier to fit than cams.
Speak to Paul whiffin or AET turbos about supplying the turbo.
:yeahthat:
T88's aint as bad as people make out but unless you are running big boost/revs on a built engine they are a waste of time imo, i bet you would love the low down grunt of a smaller turbo, the car would be miles faster.
You would have a bit of messing about to get a BW turbo fitted.
The down pipe on your turbo is four bolt and the BW is vband so you would have to mod it or buy a new one.
You might have to space the turbo up with a 10mm spacer (i had to do this when changing from a T88 to a GT4088) but its not a big deal.
You will most likely have to mod the IC pipework a little but again easy enough.
Jamie:)
I would want a turbo that can give about 650 bhp though. Am quite interested in a few years of getting a built engine done and going for higher bhp so thats why Im sort of hesitant of getting rid of the T88.
I know it's a bit wasted with my current set up.....
Ill have to look into different turbo's I think.
I have had a very big BHP T88 JUN built R32 and the change to a smaller faster spooling turbo transformed the car, a bit less power top end but boy it was a much easier car to drive fast, and it made all the power much much earlier
I had the same with Supras also, going from a T78 to a T04R the T67, the streetability of a smaller fast spooling turbo is such an advantage and makes for an everyday car
A true 550 BHP is a very fast road car
