H&R wheel spacers
super_supra
I ve just started to fit my UK spec brakes to find that my wheels dont clear i know spacers are not the best way but they will have to do untill i can find the wheels that i like and can afford.
The only H&R bolt on spacers that is stated to fit the supra is 25mm on each side i dont need to space off that much and dont want to if i dont have to.
I have found these H&R bolt on spacers 20mm thick but they are for a Toyota Corolla Verso R1 but all the size's, bolt pattan and thread's all seem the same as a supra do you think they will fit?
http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=3884652
Thaks for your help
Neil
They appear to be suitable but perhaps they don't offer that size spacer for the supra due to it's weight and potential power output having adverse effects on a thinner spacer with built-in wheel-studs.
My advise would be to measure exactly how big of a spacer you need first and then see what safe options are available.
Also listed for the Lexus GS, which is probably even heavier than the Supra :)
http://www.europerformance.co.uk/pages/products/category_results.mhtml?category=hrwheelspacers;car=lexusgs;manufacturer=hrwheels;sub_category=1
H&R
Lexus GS300/430: Total Track Widening 40mm (20mm Each Side) Hubcentric Spacers
This wheel spacer kit comes complete with all bolts required
Hubcentric Spacers
For Cars With 5 Stud Wheels
For Cars With 114.3mm PCD
Center Bore = 60.1mm
Bolt Thread = M12x1.5
and Eibach 15mm
http://www.europerformance.co.uk/pages/products/category_results.mhtml?category=eibachprospacers;car=lexusgs;manufacturer=eibachwheels;sub_category=1
EIBACH
Lexus GS, Years: 06.05 - (5 Stud Wheels)
Total Track Widening of 30mm (15mm Each Side) Hubcentric Spacers
Comes Complete With Longer Wheel Bolts/ Studs
For Cars With a PCD of 114.3/5 (Bolt/Stud Pattern)
For Cars With a Centre Bore of 60
Uses M12x1.5 Threaded Bolts/Studs
Edited by garethr (see edit history)
Do the alloys need spigot rings? If they do I would just get custom 5mm or 10mm spacers made up with the correct spigot size.
Otherwise the minimum size you can go for (hubcentric) is 10mm. Bolt on the minimum IMO is 25mm. For 20mm you would need webbed alloys.
I need about 15mm spacers was looking at the bolt on type as i had heard that fitting longer studs and normal spacers wasn't as good as the studs can snap!
not sure if my wheels have a locating spigit i will have to check i do know that it has a recess in between the bolt holes so the origanal studs will not foul on the wheels.
