TT Paul Posted November 19, 2009 Share Posted November 19, 2009 jspec tt with manu rad in the process of fitting a atogauges water temp gauge but where can i put the sender unit. or can i patch off the stock one fitted on the elbow, 1 sensor has 1 wire the 2nd has 2 wires any ideas on this Quote Link to comment Share on other sites More sharing options...
chrispot Posted November 21, 2009 Share Posted November 21, 2009 have a look on ebay as there are connectors that go in the top rad pipe into which you can put your sender unit, hope this helps regards chris Quote Link to comment Share on other sites More sharing options...
heckler Posted November 21, 2009 Share Posted November 21, 2009 jspec tt with manu rad in the process of fitting a atogauges water temp gauge but where can i put the sender unit. or can i patch off the stock one fitted on the elbow, 1 sensor has 1 wire the 2nd has 2 wires any ideas on this the two sensors on the elbow - ones for the ECU, the other is for the guage. I used an adaptor an mounted it in the Rad Pipe - much easier if you ask me Quote Link to comment Share on other sites More sharing options...
