lippy Posted November 19, 2009 Share Posted November 19, 2009 would an overfilled autobox affect its operation or is it only harmful in that it could ruin the seals? Quote Link to comment Share on other sites More sharing options...
SimonG Posted November 19, 2009 Share Posted November 19, 2009 I think if its overfilled the box will have trouble changing gear,if thats any help. Quote Link to comment Share on other sites More sharing options...
brettjones Posted November 19, 2009 Share Posted November 19, 2009 i had 2 Lt to much in mine and it changed fine only the oil when hot would get blown out the breather at the top of the box and cover the exhaust Quote Link to comment Share on other sites More sharing options...
lippy Posted November 19, 2009 Author Share Posted November 19, 2009 I think if its overfilled the box will have trouble changing gear,if thats any help. my gear changes arent smooth-it clings onto the gear too long then changes with a jerk.also it changes down quickly when you accelerate fairly lightly almost like kicking down. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 19, 2009 Share Posted November 19, 2009 It will probably overheat, foam the oil, blow a seal or generally *ugger itself up. It needs correcting, assuming you are measuring the level correctly? Autos are checked with THE ENGINE IDLING in Park. Quote Link to comment Share on other sites More sharing options...
lippy Posted November 19, 2009 Author Share Posted November 19, 2009 It will probably overheat, foam the oil, blow a seal or generally *ugger itself up. It needs correcting, assuming you are measuring the level correctly? Autos are checked with THE ENGINE IDLING in Park. thanks chris. i will check it again.when i checked it the engine wasnt running.oil was 3 inches over the hot level. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 19, 2009 Share Posted November 19, 2009 It MUST be checked running, it will be WAY over the line with the engine off as the torque converter drains back over half its oil capacity back into the sump, and it holds a lot of oil. Quote Link to comment Share on other sites More sharing options...
lippy Posted November 19, 2009 Author Share Posted November 19, 2009 thanks again chris- read dipstick when engine was running and its ok so problem must be due to some other fault. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 19, 2009 Share Posted November 19, 2009 Just found your lazy up change, jolts into gear thread. Has it got a speedo converter on it? I would try removing it and putting the wiring back to stock as a quick test. Does it do anything else, like have too fast an idle speed, or hesitations? A wrongly set throttle position sensor could do this, too. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted November 19, 2009 Share Posted November 19, 2009 If you have too much oil in your auto box it boils out at 130 and creates a smoke screen behind you. Both my Mk3 1jz and MK4 2jz did this. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted November 20, 2009 Share Posted November 20, 2009 If you have too much oil in your auto box it boils out at 130 and creates a smoke screen behind you. Both my Mk3 1jz and MK4 2jz did this. Could be a good anti chase device, like the starion in the canonball run Quote Link to comment Share on other sites More sharing options...
DSK Posted November 20, 2009 Share Posted November 20, 2009 fwiw, autog/box need the correct grade and level of oil for correct operation, incorrect fluid levels can cause a number of issues in the way they perform, such as delayed changes, jerks between selections, rattling noise (if level is low) etc. Quote Link to comment Share on other sites More sharing options...
markssupra Posted November 20, 2009 Share Posted November 20, 2009 If you have too much oil in your auto box it boils out at 130 and creates a smoke screen behind you. Both my Mk3 1jz and MK4 2jz did this. LOL, cr*pped myself when it first happened to me during a spirited drive, thought I had broken something. Been fine since I drained a litre out. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted November 20, 2009 Share Posted November 20, 2009 Well if you search back through some of my early posts you'll find a thread I started about exactly that issue ie heavy smoking at 130 Quote Link to comment Share on other sites More sharing options...
