Converting to a single turbo... help
Guest EncoreWRC
Guest EncoreWRC
Has anyone on this site written a step by step guide on how to undertake a Single Turbo Conversion??
I have done a search and had loads of hits about Single turbo projects but not a step by step guide..
I have built a Cosworth engine from new parts with the help of a mechanic friend but he is no longer local..... Any hints and tips available??
Guest EncoreWRC
I will be buying all the top stuff... want the job done properly....... Just need a little help with oil feeds etc..... and where to tap a water line from for turbo cooling.... from memory anyway..... Until I pick the bits up I don't know the exact details of what else I will need......
Just asking for any general pointers....... Or anyone who has knowledge and wants to help convert a TT to a large single as funds are now very very tight......
Don't panic dude I'll tlk you through it or come down when I'm chucking one on. Most difficult part IMO is taking the stock twins off, the rest is easy.
Guest EncoreWRC
I know I will ahve all the help I need from you guys.... and Dude... I know where you are fella so I will pop down and ask questions..... Like I say... I have a basic knowledge, intermediate mechanical skills and understanding and experience of cosworths engines.... and I am told one turbo engine is just like another.....
I am sure that a little guidance along the way and I will be fine...... For me.. removing the twins will be the easy job as its just undoing nuts and bolts.... I am more worried about installing the new bits, running oil lines etc etc... thats when I will be shouting for the help..!!!!!!
Dude, if you do plan o doing a single conversion one day... give me a shout and I will come along and be nosey!
me and robert together had every tool possible and spent 6 hours trying to remove my twin turbos off the engine. in the end, our hands were cut up, the turbos bolts were impossible to get off, so we gave up, reconnected all the vacuum lines and called it a day :D
when the car was in a proper garage, we took the engine out and it was much easier to do everything.
