Aristo VVTI into VVTI Supra- what needs changing?
jihwaan
You need to change the same stuff you would change if it was a non vvti.
The power steering pump doesn't need changing iirc.
You need to change the following to supra parts:-
Water pump
Upper sump (you can't just turn it round due to the oil drain).
Oil strum or strainer. (again you can't just turn it round as it's a different shape)
Engine mount brackets (they stick out further as the aristo engine bay is narrower)
The oil drain for the turbos are a slightly different angle but are fine to use.
Ecu etc is fine to use.
I've got a thread somewhere about swapping an aristo into a supra.
