TT Paul Posted November 16, 2009 Share Posted November 16, 2009 just been going through car no fault code as yet apart from flashing o/d light and no manu light on switch seems ok replaced blown manu bulb :( any ideas Quote Link to comment Share on other sites More sharing options...
hodge Posted November 16, 2009 Share Posted November 16, 2009 Its a traction control fault. loosen off the screws to your sub Throttle position sensor and raise it as high as possible. reset your ECU and try that. Pailing that remove your trac control stepper motor and clean it and the housing on the throttle body refit it, reset the ECU once more and off you go. My moneys on the Sub TPS though. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted November 16, 2009 Author Share Posted November 16, 2009 just been under gearbox plugs seem ok on box what you said i'll give a try let you know thanks Quote Link to comment Share on other sites More sharing options...
TT Paul Posted November 16, 2009 Author Share Posted November 16, 2009 found the tps but where is the trac control stepper motor ?? Quote Link to comment Share on other sites More sharing options...
TT Paul Posted November 16, 2009 Author Share Posted November 16, 2009 moved tps up reset ecu, no good but in diagnostic mode the o/d lite flashes either 98 or 89 code eng lite flashes continuis?? Quote Link to comment Share on other sites More sharing options...
Lee P Posted November 16, 2009 Share Posted November 16, 2009 Wont be trac control as the ecu has been removed and that normally just puts the trac light on continuously. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted November 16, 2009 Author Share Posted November 16, 2009 speed sensor possible?? trying to find auto box fault codes Quote Link to comment Share on other sites More sharing options...
hodge Posted November 16, 2009 Share Posted November 16, 2009 That's gona be ya problem then if as lee said ya trac Ecu is removed it's always gona flash an I'll get no manual mode. Just take out I/d bulb to stop it flashing. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted November 16, 2009 Author Share Posted November 16, 2009 so with trac ecu out manu wont work?? just put it back in then i guess then?? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted December 29, 2009 Share Posted December 29, 2009 just going to rebump this thread is it seemt he only one i can find relating to my problem. got my car back from the garrage and intermitantly the O/D off light will flash. the only light on the dash nothing else. no engine warning or anything like that. Half the time it is fine the other half its not. Havent had much of a chance to investigate due to weather conditions but the car runs and drives fine. havent noticed the traction control not working when the light has been flashing (i always have it on). Any advice what it might be so i can add it to my ever groing list of things that need to be done? Quote Link to comment Share on other sites More sharing options...
Dave17 Posted December 29, 2009 Share Posted December 29, 2009 Hi mate, mine has been doing this and i've put it down to very low temperatures. There is nothing wrong with my car at all, and this only happens when i cold start in temps around 0 degrees. A few minutes later when the car is warmed up it goes away. Just one of those things. Never ever happens in the Summer, only in the Winter when it gets really cold. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted December 29, 2009 Share Posted December 29, 2009 yeah mines only been doing it since it came back from the garrage though. well i came back. drove home then left for florida for a week. so its only been doing it the past 2 weeks But it happens even when the car has already been run and is warm. Quote Link to comment Share on other sites More sharing options...
Abz Posted December 29, 2009 Share Posted December 29, 2009 Any chance get opened the gearbox cover? The one under the gearshift? Mine did this when I drove without the cover on (was getting to my mates for some extra tools which replacing Dash). Then when I put everything back together it still kept flashing randomly and like you the manual button never worked. I then undid the gearbox cover to have a look and pushed and pulled a few of the wires then I noticed it just stop flashing since. Its been about 6 months since I've done my dash & touch wood it has happened again. I've put it down to a wire which I must have paid loose. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted December 29, 2009 Share Posted December 29, 2009 Any chance get opened the gearbox cover? The one under the gearshift? Mine did this when I drove without the cover on (was getting to my mates for some extra tools which replacing Dash). Then when I put everything back together it still kept flashing randomly and like you the manual button never worked. I then undid the gearbox cover to have a look and pushed and pulled a few of the wires then I noticed it just stop flashing since. Its been about 6 months since I've done my dash & touch wood it has happened again. I've put it down to a wire which I must have paid loose. could have been come to think about it. when i took it in the handbrake cable was fooked so they replaced it. So that could be the problem. I have a LOT of junk down there. uncluding a fag lighter power extention/splitter. I might give it a clear out and check when i have chance to look. will give the the excuse to pull out my dash pannel again and fix the bad spray job Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 30, 2009 Author Share Posted December 30, 2009 ive got some weird voltage readings on the trac ecu wires like the EFI- has voltage 1.77v going upto afr in jan hoping dude can fix it, if so on goes the nos.. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 22, 2012 Share Posted June 22, 2012 Was a solution to this ever found? Mines an NA-TT and manual mode doesnt work, press the button and nothing, not even a light on the dash. Any ideas? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted July 12, 2012 Share Posted July 12, 2012 Bump, anyone? Mines an NA-TT but doesnt have TRAC control either, where would I find the ecu for this? There isnt a 2nd cable connected to the TB either. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted July 13, 2012 Author Share Posted July 13, 2012 not much help but mine was never fixed tried all the units, mine needs a auto electric man to checked wires, good luck Quote Link to comment Share on other sites More sharing options...
