alex2jz Posted November 16, 2009 Share Posted November 16, 2009 Hello guys, As i am in the process of going NA-TT i am tempted to buy some parts from the US as they come cheaper. Parts like the exhaust, clutch, FMIC ect But it's the first time i attempt buying from over the pond Do you know if there any compatibility issues between these US parts and our J-Specs? Cheers Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 16, 2009 Share Posted November 16, 2009 i have baught many parts from the us and never had any fitting issues. Quote Link to comment Share on other sites More sharing options...
alex2jz Posted November 16, 2009 Author Share Posted November 16, 2009 Thank mate, just wanted to know before making a mass order Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 15, 2009 Share Posted December 15, 2009 Down pipes and exhaust manifolds can occasionally be a problem, with really big systems 4” and above, because there is a steering column in our cars where there is empty space in the USA car. Quote Link to comment Share on other sites More sharing options...
Wez Posted December 15, 2009 Share Posted December 15, 2009 Did your TT lump come from a UK or jspec, if its comes from a jspec a US/UK cat 1 replacement pipe will not fit, the flange is different, Cat 2 and onwards are all the same Quote Link to comment Share on other sites More sharing options...
David P Posted December 15, 2009 Share Posted December 15, 2009 Bought most of my bits from U.S. because half the U.K. prices. Only problem was with the Meziere water pump, 4 of the bolt holes were in the wrong place. Quote Link to comment Share on other sites More sharing options...
Wez Posted December 16, 2009 Share Posted December 16, 2009 Bought most of my bits from U.S. because half the U.K. prices. Only problem was with the Meziere water pump, 4 of the bolt holes were in the wrong place. If thats the stock gasket I would say thats the wrong pump Quote Link to comment Share on other sites More sharing options...
David P Posted December 16, 2009 Share Posted December 16, 2009 (edited) Minus the expletives, my thoughts exactly, but did not find out untill the engine was stripped down. I had checked the gasket before I started, but the offending holes were behind the label on the Toyota plastic bag. Toooo much work and trouble to send it back, so re-engineered it to fit. Edited December 16, 2009 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
