Baz018 Posted November 14, 2009 Share Posted November 14, 2009 If you look in the pics can you tell me where/what this pipe should connect upto? It starts from front of the engine and goes towards the back. Cheers Link to comment Share on other sites More sharing options...
jackso11 Posted November 14, 2009 Share Posted November 14, 2009 Am I being stupid? I can't see a pipe that isn't already connected to the correct place Link to comment Share on other sites More sharing options...
Baz018 Posted November 14, 2009 Author Share Posted November 14, 2009 the pipe in the second pic (right one) with the red line is just blanked off, hard to tell on the pic tho, Link to comment Share on other sites More sharing options...
Ian C Posted November 14, 2009 Share Posted November 14, 2009 This should help: http://www.mkivsupra.net/vbb/showthread.php?t=35926 And this: http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13945&d=1112559170 Funny old pipes to block off. The back one is #15 in the diagram, a pressure dump pipe back to the atmospheric side of the turbo from the wastegate and the ECBV. If the wastegate VSV can't vent boost pressure, it turns the wastegate into a basic spring-based setup which is quite a step backwards. Can't recall what the other piipe does, I think it's part of the emissions system. -Ian Link to comment Share on other sites More sharing options...
