JS2004 Posted November 13, 2009 Share Posted November 13, 2009 Hola! I am going to replace spark plugs tomorrow. I have had the cam cover off and the spark plug cover off to get at the coil packs, but it seems that the manifold is in the way and there would be no way to get at least two of them out without removing the manifold? Is there anything I need to take into special consideration when doing this? Its an N/A. My plan is to replace the plugs with ones from Alex's spark plug Faq, and whilst im at it im going to replace the coil packs (This is an effort to stop the misfire that im currently experiencing). I have had a look around to try and find a guide / info on this but most of the advice and write ups are for TT engines - which is a bit different Cheers! Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 13, 2009 Share Posted November 13, 2009 It isn't too bad a job, but there is a way to remove a portion of the intake manifold. Without going to the car it is a little tricky to explain. BUT it is airbox out, one or two pipes that connect up to the intake and then 4 or so bolts on the mid section. Quote Link to comment Share on other sites More sharing options...
JS2004 Posted November 13, 2009 Author Share Posted November 13, 2009 I was looking at the airbox pipe and wondering if I could take that off - its all stock in there. I spotted two bolts under the maifold looking at it head on and figured they might come into it. Im going to be playing it safe and taking pics of stuff after removing each part. Quote Link to comment Share on other sites More sharing options...
Scooter Posted November 13, 2009 Share Posted November 13, 2009 All you need to know is in this thread, its not as bad as it looks Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 13, 2009 Share Posted November 13, 2009 All you need to know is in this thread, its not as bad as it looks Cheers, I was just trying to find that The split point is just after the throttle body... No need to take the whole intake off. Quote Link to comment Share on other sites More sharing options...
JS2004 Posted November 13, 2009 Author Share Posted November 13, 2009 pure awesomeness ! thanks guys! Quote Link to comment Share on other sites More sharing options...
Digsy Posted November 13, 2009 Share Posted November 13, 2009 When you say "replace the coil packs" do you mean the HT leads? NA's don't have coil packs. They have a dizzy on the exhaust side of the cylinder head, After about 120,000 miles I went to change my spark plugs and but the tops of the HT leads came off in my hand when I tried to pull them out. Apart from having to get a new set of those it wasn't a difficult job. You don't have to take as much apart as it looks. Quote Link to comment Share on other sites More sharing options...
nevins Posted November 13, 2009 Share Posted November 13, 2009 anyone know a good supplier for plugs and leads that is not going to brake the bank as the cheapest leads i can find is £98 Quote Link to comment Share on other sites More sharing options...
JS2004 Posted November 14, 2009 Author Share Posted November 14, 2009 I got my leads from Keron that set me back £30 delivered. New from Mr T were 100+ Digsy, its the leads that go into the spark plugs yes =) I was told by Mr T that they were the same part for TT and N/A but Keron told me different, so im not sure of the official name right now, but its them cables They feed right under the manifold which is the bit I was worrying about. Quote Link to comment Share on other sites More sharing options...
JS2004 Posted November 14, 2009 Author Share Posted November 14, 2009 (edited) *gulp* this doesnt look like its a fun job LOL why did they put that manifold over the engine like that *tut*. The good thing is that I can use this as my argument when im trying to justify a TT purchase (grin) After all this messing it better sort out my misfire lol Edit - the more I read this and look at those documents and pictures.. the easier it seems Edited November 14, 2009 by JS2004 (see edit history) Quote Link to comment Share on other sites More sharing options...
Marco79 Posted November 14, 2009 Share Posted November 14, 2009 Mate it's well easy when u get into it I can have the throttle body and twin branch manifold off in 20-30 mins, you will have no probs just get stuck in Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 14, 2009 Share Posted November 14, 2009 (edited) anyone know a good supplier for plugs and leads that is not going to brake the bank as the cheapest leads i can find is £98 I can get o/e toyota for £107 leads, £20 dizzy cap, £7.48 rotor arm, £6.68 plugs each all inc vat or i can get cost on non o/e if you wish mate Edited November 14, 2009 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
JS2004 Posted November 14, 2009 Author Share Posted November 14, 2009 Which plugs would they be DNK? I went with platinum ones came to £53 delivered for 6. After searching on here though there was a website that was selling the Denso PK16R11 for 6.6 each (before VAT). Im fairly sure Keron said he had two sets of leads available when I spoke to him last week though Nevins - I would give him a call if your not too fussed about getting second hand ones (although theyre still going to be roughly 15 yrs old). Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 14, 2009 Share Posted November 14, 2009 The plugs ive listed at £6.68 each inc vat are Toyota o/e which retail at £12 each. Not sure what they are but guess their platinum for that money. Quote Link to comment Share on other sites More sharing options...
Digsy Posted November 14, 2009 Share Posted November 14, 2009 Christ, I don't recall my HT leads from Toyota being over £100! I'll go and dig out the reciept. Get the proper Toyota ones. They even come all pre cipped and arranged. All you have to do is lay them in the valley and push them home, then bolt down the clips. FWIW I'd get the standard Toyota plugs too. £6 / £7 eacj isnt bad considering how long they last. Incidentally, I guess that Toyota used platinum tipped plugs on the NA because changing them isn't a five minute job, so it would help keep regular service (labour) costs down. Quote Link to comment Share on other sites More sharing options...
Digsy Posted November 14, 2009 Share Posted November 14, 2009 Ok, I Stand corrected. £94.93 + VAT but I got a 15% discount. I'd still get the standard parts though. Quote Link to comment Share on other sites More sharing options...
