Tricky-Ricky Posted November 13, 2009 Share Posted November 13, 2009 Sorry but in need of some more help with it:( it seems that when she had the shunt the heater has not worked, what i need to know is how to remove the panel with the heater controls, and also how the control operates? The heater switch feels very light so i am assuming its electronically controls a servo? Is this a common fault, and is there an easy fix? Quote Link to comment Share on other sites More sharing options...
Multics Posted November 13, 2009 Share Posted November 13, 2009 I'm not very familiar with the KA's but if everything fails you can always buy her this nice heater: Quote Link to comment Share on other sites More sharing options...
keron Posted November 13, 2009 Share Posted November 13, 2009 do they not work at all? not blowing anything? Quote Link to comment Share on other sites More sharing options...
nevins Posted November 13, 2009 Share Posted November 13, 2009 Pull the knobs off the control panel and you should see some phillips screws there mate that hold them in place, dont quote me on that as i aint worked on a KA for about 2 years lol Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 13, 2009 Share Posted November 13, 2009 "daughters ka" we belive you, honest Quote Link to comment Share on other sites More sharing options...
Axle Posted November 13, 2009 Share Posted November 13, 2009 Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted November 13, 2009 Share Posted November 13, 2009 Is it not blowing hot air by any chance? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted November 13, 2009 Share Posted November 13, 2009 If so, its nothing to do with the controls. Its a hugely common fault on fiestas, Ka's and pumas (all the same chassis). It's the heater control valve. Its piss easy to replace and takes about 10 minutes. The valve is located on the front of the bulkhead at the top in the center. you'll see two coolant hoses running into it. Undo the hoses from both sides and remove the multiplug. Pull the old unit out and replace, job done........I knew that apprenticeship at ford would pay off Here is the valve http://www.fordpartsuk.com/images/1454023.jpg Even better, heres an over the top 'how to guide with pics' http://www.khantazi.org/Archives/Ford_Ka_Heater_Valve_Repair/ValveRepair.html Quote Link to comment Share on other sites More sharing options...
keron Posted November 13, 2009 Share Posted November 13, 2009 thats what i was thinking...had to change a few in the past. If so, its nothing to do with the controls. Its a hugely common fault on fiestas, Ka's and pumas (all the same chassis). It's the heater control valve. Its piss easy to replace and takes about 10 minutes. The valve is located on the front of the bulkhead at the top in the center. you'll see two coolant hoses running into it. Undo the hoses from both sides and remove the multiplug. Pull the old unit out and replace, job done........I knew that apprenticeship at ford would pay off Here is the valve http://www.fordpartsuk.com/images/1454023.jpg Even better, heres an over the top 'how to guide with pics' http://www.khantazi.org/Archives/Ford_Ka_Heater_Valve_Repair/ValveRepair.html Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted November 13, 2009 Share Posted November 13, 2009 If so, its nothing to do with the controls. Its a hugely common fault on fiestas, Ka's and pumas (all the same chassis). It's the heater control valve. Its piss easy to replace and takes about 10 minutes. The valve is located on the front of the bulkhead at the top in the center. you'll see two coolant hoses running into it. Undo the hoses from both sides and remove the multiplug. Pull the old unit out and replace, job done........I knew that apprenticeship at ford would pay off Here is the valve http://www.fordpartsuk.com/images/1454023.jpg Even better, heres an over the top 'how to guide with pics' http://www.khantazi.org/Archives/Ford_Ka_Heater_Valve_Repair/ValveRepair.html Thats the one! Before i was VW man i was a Ford Fanatic spent about £15k on my fiesta and learnt pretty much everything during the build over many yers! KA's and fiestas have the same set ups pretty much and if your not getting hot air its 99.9% the control valve. There aout £50 from ford. Very asy to fit. It sits in the bulkhead and you will see the inlet pipe goin in and one coming out. Drain your anti freeze, then its a 5 minute fit, connect the pipes and jobs a gooden good luck mate and i hoped i helped a bit. Paul Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 13, 2009 Author Share Posted November 13, 2009 If so, its nothing to do with the controls. Its a hugely common fault on fiestas, Ka's and pumas (all the same chassis). It's the heater control valve. Its piss easy to replace and takes about 10 minutes. The valve is located on the front of the bulkhead at the top in the center. you'll see two coolant hoses running into it. Undo the hoses from both sides and remove the multiplug. Pull the old unit out and replace, job done........I knew that apprenticeship at ford would pay off Here is the valve http://www.fordpartsuk.com/images/1454023.jpg Even better, heres an over the top 'how to guide with pics' http://www.khantazi.org/Archives/Ford_Ka_Heater_Valve_Repair/ValveRepair.html Thanks mate i had a feeling you would come up with the solution:innocent: don't suppose you have any idea on the rough price of a replacement? And no its not mine, and no i'm not putting pics up to prove it, as i know i would have to come and thump some of you for the out of order comment's, as she is quite pretty. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted November 13, 2009 Share Posted November 13, 2009 Thanks mate any idea on the rough price of a replacement? Last one I bought was about £25. Quote Link to comment Share on other sites More sharing options...
