Help With Daughters Ka (again!)
Tricky-Ricky
Sorry but in need of some more help with it:( it seems that when she had the shunt the heater has not worked, what i need to know is how to remove the panel with the heater controls, and also how the control operates?
The heater switch feels very light so i am assuming its electronically controls a servo?
Is this a common fault, and is there an easy fix?
If so, its nothing to do with the controls. Its a hugely common fault on fiestas, Ka's and pumas (all the same chassis). It's the heater control valve. Its piss easy to replace and takes about 10 minutes.
The valve is located on the front of the bulkhead at the top in the center. you'll see two coolant hoses running into it. Undo the hoses from both sides and remove the multiplug. Pull the old unit out and replace, job done........I knew that apprenticeship at ford would pay off :D
Here is the valve
http://www.fordpartsuk.com/images/1454023.jpg
Even better, heres an over the top 'how to guide with pics' :D
http://www.khantazi.org/Archives/Ford_Ka_Heater_Valve_Repair/ValveRepair.html
thats what i was thinking...had to change a few in the past.
Here is the valve
Here is the valve
Thats the one! :)
Before i was VW man i was a Ford Fanatic spent about £15k on my fiesta and learnt pretty much everything during the build over many yers! KA's and fiestas have the same set ups pretty much and if your not getting hot air its 99.9% the control valve. There aout £50 from ford. Very asy to fit. It sits in the bulkhead and you will see the inlet pipe goin in and one coming out.
Drain your anti freeze, then its a 5 minute fit, connect the pipes and jobs a gooden :) good luck mate and i hoped i helped a bit.
Paul
Here is the valve
Thanks mate :) i had a feeling you would come up with the solution:innocent: don't suppose you have any idea on the rough price of a replacement?
And no its not mine, and no i'm not putting pics up to prove it, as i know i would have to come and thump some of you for the out of order comment's, as she is quite pretty.
