decat gaskets
jackso11
Got my decats to put on, second hand so no gaskets.
Lots of different threads with opinions on types of gaskets but not how many I will need, or if using gasket paper, what thickness.
So, manifold -- gasket -- 1st Decat -- gasket -- restrictor ring -- gasket -- 2nd Decat -- gasket -- back box.
Is that right? if so, what thickness, or should I just used gasket paste?
gasket paste, is it all the same?
It's called exhaust assembly paste, an off white paste.
Don't confuse it with repair paste/putty.
Expensive at Halfords.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_164909_langId_-1_categoryId_165625
Your local car shop should have some cheaper.
