jackso11 Posted November 13, 2009 Share Posted November 13, 2009 Got my decats to put on, second hand so no gaskets. Lots of different threads with opinions on types of gaskets but not how many I will need, or if using gasket paper, what thickness. So, manifold -- gasket -- 1st Decat -- gasket -- restrictor ring -- gasket -- 2nd Decat -- gasket -- back box. Is that right? if so, what thickness, or should I just used gasket paste? Link to comment Share on other sites More sharing options...
jackso11 Posted November 13, 2009 Author Share Posted November 13, 2009 (edited) Also, how come the shape of second decats seems to vary so much? Like these, both jspec second decats but look so different? Also, if someone could supply me with the gaskets needed give me a shout Edited November 13, 2009 by jackso11 (see edit history) Link to comment Share on other sites More sharing options...
supspower Posted November 13, 2009 Share Posted November 13, 2009 Alot of people seem to just use paste and all seems fine, if not can always measure the length from hole to hole on the flange and see if any of these will be of use, i used some on my previous supra and all was fine...thickness wise 3mm i think would be enough. http://www.blitz-uk.co.uk/Product-14.aspx Link to comment Share on other sites More sharing options...
supspower Posted November 13, 2009 Share Posted November 13, 2009 To the first pic i cant see that being the correct pipe for a mkiv?? Link to comment Share on other sites More sharing options...
jackso11 Posted November 13, 2009 Author Share Posted November 13, 2009 its listed on whifbitz as a blitz pipe to replace 2nd cat Link to comment Share on other sites More sharing options...
supspower Posted November 13, 2009 Share Posted November 13, 2009 Havent got a clue then, maybe theres a 2nd bit to the pipe thats not shown? Link to comment Share on other sites More sharing options...
merckx Posted November 13, 2009 Share Posted November 13, 2009 or should I just used gasket paste? That's all I ever use, make sure you use sufficient. Link to comment Share on other sites More sharing options...
jackso11 Posted November 13, 2009 Author Share Posted November 13, 2009 gasket paste, is it all the same? I have some black gasket silicone I got for a sump on a mazda and I also have some copper coloured silicone gasket I got for a small odd job. Not sure where the black stuff is. Is it all the same or does it come in temp grades? Link to comment Share on other sites More sharing options...
merckx Posted November 13, 2009 Share Posted November 13, 2009 gasket paste, is it all the same? It's called exhaust assembly paste, an off white paste. Don't confuse it with repair paste/putty. Expensive at Halfords. http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_164909_langId_-1_categoryId_165625 Your local car shop should have some cheaper. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 13, 2009 Share Posted November 13, 2009 I keep gaskets in stock. E-mail me with yor needs if you like, or phone, thanks. Link to comment Share on other sites More sharing options...
jackso11 Posted November 13, 2009 Author Share Posted November 13, 2009 £3.79 isn't really that expensive is it?! Link to comment Share on other sites More sharing options...
merckx Posted November 13, 2009 Share Posted November 13, 2009 £3.79 isn't really that expensive is it?! Not really but the local car shop sell it for about half that price, depends on how far you have to travel. Link to comment Share on other sites More sharing options...
