Steve Gee Posted November 4, 2002 Share Posted November 4, 2002 Hi All, Problem 1. In performing a "kill" of three hot hatches in a row, (they were in convoy are were NOT happy) the car hit 120 no problem. But then it cut out, (lost power) momentarily and then cut back in, and within two seconds cut again. It did this four times! I then decelerated and all was fine, and has been since. It was as if I was hitting a limiter, but I was nowhere near that kind of revs, and I've been way faster than that before. Any ideas? Problem 2 Now that the dark mornings and nights are on us, I noticed my lights brighten when engine revs are taken over 1500 revs. I've measured the voltage across the battery at tickover with no electrical load at 13.6V. However with electrical load it drops to 12.5 and sometimes lower. Some times in the mornings the Heated Rear Window won't stay on, until I turn my lights off! So it looks like alternator is on the way out. Anyone replaced one before? How difficult and how much are they to buy? Any assistance greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Thorin Posted November 5, 2002 Share Posted November 5, 2002 Problem 1 : Speed limiter (edited because I read you had been faster before, so your speed delimiter is probably borked). Problem 2 : er, no idea. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted November 5, 2002 Share Posted November 5, 2002 Problem 2: Could be a battery with a dead cell or similar, get the battery checked first. If it's really old you may just want to swap it out anyway. Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted November 5, 2002 Share Posted November 5, 2002 Problem 1, did you get a red triangle in the middle of the dashboard when it happened. If so could well be fuel cut. What state of tune is your car in? Quote Link to comment Share on other sites More sharing options...
jagman Posted November 5, 2002 Share Posted November 5, 2002 problem 2 could be alternator brushes worn ...cheap fix Quote Link to comment Share on other sites More sharing options...
Steve Gee Posted November 6, 2002 Author Share Posted November 6, 2002 Does "borked" mean broken? (or words to that effect!!) The car never has a problem turning over or starting, so I had ruled out the battery, but will get it tested. There were no warning lights at all. How difficult is the alternator to remove. From underneath I would think? Thanks for the replies. Steve Quote Link to comment Share on other sites More sharing options...
Steve Gee Posted November 6, 2002 Author Share Posted November 6, 2002 Whoops, forgot! The car is standard, apart from straight through exhaust and Ramair panel filter. I run it on Optimax as much as possible. Cheers Steve Quote Link to comment Share on other sites More sharing options...
roboldham Posted November 8, 2002 Share Posted November 8, 2002 Problem 1: You didn't say so but I bet you a tenner you were very low on fuel when you performed your multi-kill. I had EXACTLY the same problem (although it was at 145!) - and thought it was fuel cut - but mine is stock so wouldnt have got to that level, and I haven't been able to replicate since. I have spoken to a couple of others with same issue - and it always happened at low fuel levels - vapour pocket? R Quote Link to comment Share on other sites More sharing options...
Steve Gee Posted November 11, 2002 Author Share Posted November 11, 2002 I can't remember what my fuel situation was at the time, but I'll monitor it from now on. I've tested my battery and it still show 11V while constantly turning the engine over. So looks like I'll have to whip the alternator out. Has anyone done this before? How difficult? Thanks. Quote Link to comment Share on other sites More sharing options...
Terminator Posted November 11, 2002 Share Posted November 11, 2002 It will not be simple thats for sure, probably find you have to take have the car apart;) I have had batteries start the car OK but give dim lights etc, when checked with a tester, one cell was on the way out. Quote Link to comment Share on other sites More sharing options...
