Help with Cutting Out (and Alternator)
Steve Gee
Hi All,
Problem 1.
In performing a "kill" of three hot hatches in a row, (they were in convoy are were NOT happy) the car hit 120 no problem. But then it cut out, (lost power) momentarily and then cut back in, and within two seconds cut again. It did this four times! I then decelerated and all was fine, and has been since. It was as if I was hitting a limiter, but I was nowhere near that kind of revs, and I've been way faster than that before. Any ideas?
Problem 2
Now that the dark mornings and nights are on us, I noticed my lights brighten when engine revs are taken over 1500 revs. I've measured the voltage across the battery at tickover with no electrical load at 13.6V. However with electrical load it drops to 12.5 and sometimes lower. Some times in the mornings the Heated Rear Window won't stay on, until I turn my lights off! So it looks like alternator is on the way out. Anyone replaced one before? How difficult and how much are they to buy?
Any assistance greatly appreciated.
Guest Martin F
Problem 2: Could be a battery with a dead cell or similar, get the battery checked first. If it's really old you may just want to swap it out anyway.
Does "borked" mean broken? (or words to that effect!!)
The car never has a problem turning over or starting, so I had ruled out the battery, but will get it tested.
There were no warning lights at all.
How difficult is the alternator to remove. From underneath I would think?
Thanks for the replies.
Steve
Problem 1:
You didn't say so but I bet you a tenner you were very low on fuel when you performed your multi-kill.
I had EXACTLY the same problem (although it was at 145!) - and thought it was fuel cut - but mine is stock so wouldnt have got to that level, and I haven't been able to replicate since.
I have spoken to a couple of others with same issue - and it always happened at low fuel levels - vapour pocket?
R
I can't remember what my fuel situation was at the time, but I'll monitor it from now on.
I've tested my battery and it still show 11V while constantly turning the engine over. So looks like I'll have to whip the alternator out. Has anyone done this before? How difficult?
Thanks.
